Cuts out mid driving
Skeletroopa
92 VP V6
Ok, My 92 vp v6 cuts out mid driving, doesnt matter whether its going round a corner, a slight bend or a straight, i gotta be quick enough to snap it back to nutruel to restart the engine, any suggestions... :bang:
rob drag racer
vn vp drag nut
golden beach
forums.justcommodores.com.au
vp 3.8 with gas new project vn s1 guted strip only
anarklov3r
2007 WM Caprice
i had a similar problem. It ended up being that huge plug that plugs into the DFI module (under the ignition coils)
Grab a socket set, unbolt the connectors, blow out all the gunk in it, spray some WD-40 in it, plug it in and out a few times, then blow it out once more (to get rid of all that newly loosened junk) and spray again.
Might also be your Crank Angle Sensor (CAS). Unless you have a pulley to take of your harmonic balancer, you wont be able to change it yourself. I got mine changed at the local auto electrician for $150
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
or the security key in the passenger door jam if you have that
