Cv drive shaft bolts
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jay_commo, Jun 30, 2020 at 4:52 PM.
  1. jay_commo
    jay_commo New Member
    96 VS Calais l67
    Replacing the cv drive shafts in my 96 vs calais and ive found some of them are stripped and need replacing so before trying to take them i thought id ask what bolts they're and if anyone knows where to get new ones from
  2. Deuce
    Deuce Super Stock
    '94 VR SS V8
    I've bought one from holden several years back. $8 each from memory.
    I'll find you a part number if you like.
  3. Deuce
    Deuce Super Stock
    '94 VR SS V8
    92180093 is the part number
    jay_commo likes this.
  4. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    A fastener shop should have them, unless they are specific length that is not in the common sizes.
  5. Deuce
    Deuce Super Stock
    '94 VR SS V8
    I should have measured one.
    They are a fine thread, and have an unthreaded shank.
    I wouldn't use any bolt in them. I would hate to sheer 6 bolts off because they couldn't handle the job and then I'm stranded.
  6. losh1971
    North Tas
    VR Ute V6
    You would grab rated bolts not just mild steel.
  7. losh1971
    North Tas
    VR Ute V6
    I had to replace one of mine and I bought it from a fastener shop ( Nut & Bolts).
  8. Tonner Matt
    Tonner Matt Well-Known Member
    Darwin
    VZ 1 Tonner LS1 M6
    Some manufacturers supply the new bolts with their shafts
    Check with whoever you're buying the shafts from to find out if they come with new bolts or not
    losh1971 likes this.
  9. losh1971
    North Tas
    VR Ute V6
    I thought the OP was talking about the centre CV, then just saw TMs reply and it the IRS shafts the OP was referring too.
  10. vc commodore
    vc commodore Well-Known Member
    south australia
    vc commodore
    Question begs...Why are they stripped? To me if a bolt is stripped, the thread the bolt goes through would be stripped also...So I'd be checking that too, before going to much further
  11. EYY
    EYY Well-Known Member
    VS Statesman
    Because they’re bloody tight are fitted with red loctite. They’re a grade 12.9 cap head bolt. Fine thread - at a guess m10x1.0.
    Most common cause is dirt in the head of the fastener. This means the 8mm hex can’t bottom out in the cap head and strips the head out when force is applied.
    I always clean them out well and use an impact socket and impact gun and have no issues. For the damaged ones, I tap a torx socket into the head of the bolt and then use the impact gun.
    jay_commo and Utel67 like this.
  12. jay_commo
    96 VS Calais l67
    Cheers for the info guys
  13. vc commodore
    south australia
    vc commodore
    I surpose the way I should have asked the question is, what part is stripped? The head of the bolt, or the thread of the bolt....
  14. Deuce
    Deuce Super Stock
    '94 VR SS V8
    I assumed the OP meant the hex key in the head was stripped, as he hasn't removed them yet and is preparing for replacement so can remove by force.
  15. jay_commo
    96 VS Calais l67
    The head mate
  16. vc commodore
    south australia
    vc commodore
    I saw it as some threads were stripped, rather than the heads....Anyways, it has been confirmed wart was stuffed, so mystery solved :)
  17. vc commodore
    south australia
    vc commodore
    Thanks for confirming it :)
