Cv shaft
Jye-forro
22
Vz Calais v6
Hey fellas, I’ve done a cv… just wondering how I got about cracking the Allen key bolts?? I’ve used the jack on the end of a breakerbar and they’re that tight they’re near lifting the car…
Thanks in advance
Car is a vz Calais sedan
mechanic
Australia
Commodore
Here are my tips:
1. A good quality tool. Cheap hex tools are rubbish when doing heavy work. Spend $25 and buy a good quality single hex key socket to suit the size bolt you have, if you don't have one already. The last thing you want is a rounded off tool/bolt or broken knuckles.
2. Lubricate the bolt. The best penetrating oil is made yourself by mixing about 80% auto trans oil and 20% acetone. It's super thin and the acetone carries the oil into every last gap. Try to build a dam around the bolt with something so that it pools and has time to soak past the threads. See if you can access the back of the bolt to get directly to the threads.
3. An impact gun is designed specifically for seized/frozen fasteners - that's why mechanics use them so much. The rattling action shocks/shears the bolt thread apart without fracturing the metal body of the bolt or tool head (it will break off if you rattle for too long, but short bursts are ok).
4. Heat. If the bolt is corroded or has too much loctite on it, you'll need some heat to thermally shock the thread, or soften the thread compound. It doesn't need to be much heat (needs to be just too hot to touch), but make sure it has time to conduct through the component to the thread interface. Put your oxy-acetylene kit away... a hot-air gun is enough, and won't start a fire/melt rubber.
5. Cold. If heat alone won't do it, hit the bolt head with freeze spray when the component is still hot. The thermal shock from the temperature difference will be greater.
6. If you still can't get it off, you have three options.
a. Use a long lever and break the bolt, or cut/drill the bolt out and repair the thread. There are plenty of thread repair guys that will come to your home to do this for you. If you think the job is awkward, I guarantee you that they've done a harder job before. I swear these guys have arms with four elbows.
b. Remove the whole component (if possible) and get better leverage on the bench. Depending on the part this may not be feasible.
Good luck. Let me know how you go.
Fu Manchu
WA.
Whoa! Do you mean you used an allen key with the jack handle over it! Oooo no.
Jye-forro
22
Vz Calais v6
Here are my tips:
Hey mate, thank u very much the trans oil mix worked a treat with a little persuasion! Much appreciated
Fu Manchu
WA.
No. No no no.
Get the proper hex socket as previously mentioned. ½” if possible. Long ½” breaker bar.
Give them a squirt with some WD40 overnight.
Jye-forro
22
Vz Calais v6
No. No no no.
Had a good key to suite and had longest extension bar I could fit under the car with a lot of wd40 lol
_R_J_K_
Zenki S14
Not very long as it was the only one I could fit under the car while it’s on jack stands :(
Do your jack stands not go very high? You need more leverage, so get the car higher to get a longer breaker bar under there. The breaker doesn't need to be vertical, you just need to crack the bolt and then you can undo it with something shorter.
  • Like
Reactions: Lex
