eddy6241
- Oct 31, 2019
- 24
- 9
- 3
- Age
- 49
- Location
- Adelaide
- VZ Wagon Exec Dual Fuel
Strange issue would appreciate some help.
car developed misfire, stopping and starting the engine fixed it a couple times for a few days, but now makes no difference constant misfire in cyl 6. it starts and runs on 5 cylinders. it drivable, but poorly.
pulling the connector plug off on coilpack 6 only makes no diff to the misfire, therefore it must be cylinder 6. (pulling plug on other coilpacks makes misfire worse.)
however removing coilpack and plug from #6 and stiiting it on manifold (with a spare plug back in plughole 6) and sparks fine! i did the same procedure on cyl 1 to compare spark strength , and spark is about the same.. so why misfire?
the car is dual fuel, and same issue on gas or petrol, i flicked between the two when warm and made no difference. and spark plug comes out wet when cold (starts on petrol) , so there seems to be fuel.
compression on #6 with engine running does seems low, reving it a bit on a cold engine = about 100psi, but surely this is enough psi for combustion? cylinder 1 was 140psi . i havent checked others.
i thought maybe it was ECU, since the problem cleared that time by restarting the car couple times. plugs and coils were all done a few months ago with the same symptom, it didnt go away initially, but then did after fiddling around it came good for a few months, now im wondering if the coils and plugs were ever the issue..
any help or ideas would be greatly appreciated..
ive read a stretched timing chain or head gasket issue could theoretically cause this, but why did it come good after a stop/restart those couple times.. and i dont want to go down that path to find it was much simpler... the engine 235000kms. no mods.
