Cylinder head bolt removal.
_R_J_K_
Zenki S14
Look, the point is I don't get why you would think using a torque wrench would somehow make it easier to get a bolt undone. You need more leverage or to put your back into it.
losh1971
North Tas
VE Series I SS Ute
correct tool
Incorrect tool..... ;);)
losh1971
North Tas
VE Series I SS Ute
A piece of water pipe is lot cheaper. If its a metre long, has a lot more leverage (if you have room).
Yeah but even then you want a strong head on your short breaker or it can snap or bend.
Thing these days with a lot of modern engines only torque up fairly low but then you get out the breaker bar to turn the extra 1/4 turn. I know you can turn the torque wrench right up but like mentioned most are ratcheting. And with the load on the bar i wouldn't want go the last bit using my TW. It's enough to stretch a hi-tensile head bolt, I wouldn't risk it, going all the way or undoing head bolts but that's just me.
My bar has plenty of leverage, i snapped a 14mm hi-tensile suspension bolt with it.
Dylan kingswood
33
Hobart
2011 s2 Ve ss
Says the bloke that can’t unbolt a set of alloy heads
Fu Manchu
WA.
I can’t get the pedals off Miss 5’s pushie. Until I do, she can’t do any sick jumps.
wetwork65
A wet business
VF SSV Wagon & VF SV6 Wagon
Careful of your torque wrench. Don't wreck it on her pushie - you may need it to remove Alloytech cylinder heads, instead of a breaker bar.
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
My cigarette lighter socket won't undo with a 25 mm open ender. The manual says it should only be finger tight. Would it be safe to use my torque wrench after I strip out the dash to get it behind there?
