D3V14NT
Likes Shiny Things
- May 26, 2009
- 185
- 3
- 0
- Location
- Geelong, Vic
- 93 VP BT1 V6
I bought this for $1000 about 8 months ago and has probably cost twice that again since then.
White 1993 VP Executive BT1 3.8L. It has the executive code in the VIN however it has a Berlina interior - dash badge and full electrics - and a berlina badge on the boot.
KMs: This cluster - 233 xxx, Previous Cluster - 282 xxx, Cluster before that - no idea
Engine: Stock
Transmission: Stock
Exhaust: 2.5" Cat Back - straight through muffler no resonator with a shiny tip on the end. Not the best sounding exhaust but can't complain too much for $100 brand spanking new.
Brakes: Stock
Suspension: Stock
Interior: Stock
Exterior: White Chevoit Wheels
At the moment the goal is just to replace everything thats broken, in a sense it's a bit of a project car because there is a lot that's broken.
What I've done so far:
23-01-2010 More Repairs
What I still have left to do:
So theres still a fair way to go to get it all sorted but I'm determined and I've certainly done quite a bit so far so may as well keep at it. I've attached a few photos of the old girl.
I'll keep this post updated as I go.
Engine: Stock
Transmission: Stock
Brakes: Stock
Suspension: Stock
Interior: Stock
- Replaced Idler Pulley Twice. First one was too narrow and chewed two belts. Second one made a terrible noise.
- Replaced the belt four times
- New Alternator Regulator
- Replaced the engine bay fuse box cover but it's broken again as the bottom of the fuse box is warped and it broke trying to get it off again
- Replaced battery terminals
- Replaced windshield washer motor
- Replaced thermostat
- Replaced water temp sensor (to gauge)
- Replaced Instrument Cluster
- Fitted new intake manifold gaskets twice. Over tightened it the first time so ended up having to do it again.
- New plugs and leads
- New air, oil and fuel filters
- Thoroughly cleaned the intake manifold, throttle body and the elbow inbetween
- Removed Bellmouth
- Replaced Throttle Cable
- New glovebox pin
- New console ashtray and rear door ashtrays
- Repaired both front side air vents
- Replaced top and bottom radiator hoses
- Replaced both transmission fluid hoses to radiator
- New wiper blades
- New power antenna but the mast broke in it
- Amazingly I found the exact same set of wheels on a vn at a wreckers so I got myself a center cap to replace the one with no sticker on it, just haven't done it yet
- Replaced front left wheel bearings
- Replaced front brake pads
- Replaced rear left hand brake shoes and retainer spring
- New cat back exhaust, 2.5" straight through - wanted a dog leg muffler rather than straight through but couldn't get it at the time
- 4x new tyres
- New transmission mount
- New odometer cog
- Countless new interior globes
- New left power mirror
- New power mirror toggle switch thingy
- Replaced the little square piece of carpet in the console
- Unblocked air con drain pipe
- Removed, washed and refitted carpet
- Fixed an air vent vacuum leak
- Replaced headlight globes
- Replaced the tail lights
- Replaced the timing chain and gears
- Drilled out and replaced the bolt I sheared off in the block through the timing cover
- Bought a dash mat
- Replaced Oil Pressure Switch
- Replaced MAP Sensor
- Replaced Engine Bypass Coolant hose
- Replaced front oil seal - the one the balancer sits in
- Fitted Speedy Sleeve to the harmonic balancer - had a groove worn in the shaft.
- Used shitloads of oil before I replaced that seal haha
- Replaced rubber bung that was missing in the firewall
- Replaced Exhaust manifold gaskets after noticing that 5 studs in total were finger tight (one was half unscrewed actually) and one cross-threaded stud
- Replaced missing wheel nuts after rear left wheel fell off while driving at night (long story)
- Replaced Handbrake lever assembly - pain in the ass of a job that one
- Replaced cigarette lighter socket
- Replaced a lot of fuses
- Replaced both alternator bearings.
- New Oxygen Sensor
- New Coolant Temp Sensor (To ECU)
- New PCV Valve
- New ECU (2nd Hand but tested and working)
- New seat covers to hide the rips
- New Speed Sensor
- New clip for the cover under the steering wheel
- New rubber grommets to plug those holes in the rear foot wells under the carpet
- Replace Catalytic Converter
- Replace IAC
- Fix central locking - it stopped working last time I took the dash apart and I still haven't figured out why
- Fix the driver side window as it falls forward in its track, also need to replace the rubber thats on the inside of the rear track as its missing and the rattle drives me nuts
- New mast for the power antenna
- Rebuild/Replace Engine
- Get a new button and handle for the handbrake lever, then I can tighten it up again.
- Fix insanely hard bonnet release. Even with the bonnet already open this level is a nightmare to pull.
- Replace bonnet release lever as it broke the plastic mounts off
- Replace drivers side kick panel
- Fix the cross-threaded exhaust manifold stud
- Fix non working boot light
- Fix non working boot opening button in glovebox
- Buy a decent sound system.
- Replace windshield - noticed a crack in it today coming up from the bottom, too long to repair
- Fix up a few small rust spots, stone chips, scratches and some damage on the bumpers.
- Give the car a damn good clean
