DAKSTER
Beam me up Scotty!
- Mar 5, 2011
- 1,981
- 40
- 48
- Location
- Woodford QLD
- VS Berlina
I fixed the seatbelts on the Acclaim too. They werent retracting and I had planned to use the ones from the Berlina to get it RWC and just buy some brand new ones for the Berlina later. It turns out not to be necessary.
I took the plastic trim off from over the front drivers seatbelt, and tried the seatbelt directly out of the spool. It retracted rapidly and easily, so I figured the mechanism must be ok. Its only when it meets the resistance of the buckle it feeds through that it seems to stick.
I got a bucket of water and dishwashing liquid, and one of those green scotchbrite pads, and gave the seatbelt webbing a thorough clean. Then I tried the seatbelt and it had improved, but was still not retracting well enough. When it was totally dry, I tried it again and it had improved a little more.
Then I sprayed it with silicone spray. Tried it again, while the spray was still damp, and it was much better. Not great, but probably good enough for RWC, so I let it be.
Next morning I came out and tried it, and with the silicone spray now totally dry, the seatbelt works like brand new.
Problem solvered boss.
