dam Empty
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Wire, Oct 4, 2005.
  1. Wire
    Wire New Member
    Kadina, SA
    VR Exec 94
    I just got my 94 VR exec and was wondering does it have a fuel light? in the manual it explains that it should come on as a test when the ignition is turned on but turn itself off when the engine is started (if fitted).. *if fitted being the keyword* i turned on the ignition and failed to see a fuel light on the dash. the fuelguage has been on empty 4 a while now if theres no fuel light maybe i should fill it up :thumbsup:
  2. deathsminion
    deathsminion Chrgd,Coold,Twinthrot'in
    GT42R forced JZA80 Supra and VT Wagon
    VR execs generally don't have them. At least mine doesn't. :)
  3. Fekason
    Fekason Fekason
    Penrith NSW
    VS S2 Executives have them.
    The other possibility is that the light bulb in the dash has blown.
  4. Wire
    Wire New Member
    Kadina, SA
    VR Exec 94
    Is their an easy way 2 check if its blown.. if their even is 1 lol
  5. Freddy Kruger
    Freddy Kruger Member
    '09 VE SS UTE
    you could get a light a shine it onto the dash and have a look to see if its there. i noticed while driving that if light is on the right angle you can see if its there. but then again my VS had one for ABS ( i think) which it doesnt have.
  6. Fekason
    Fekason Fekason
    Penrith NSW
    Take the cluster out, or?
    The easiest way is to take the cluster out.
    If you have small, strong fingers and know where it is, you might succeed in extracting it with the cluster still installed.
    I managed to get one out, but could not reinsert it.
  7. seabass
    seabass New Member
    Geelong, VIC
    VS Berlina 3.8 M5
    i didn't have to take the cluster out to install me cruise lights in the dash. just remove the panel under the stering colum and it is awekward but look up you shoud b able to see the back of the gloves, then just get a pair of needle nose pliers adn turn the bulbs anti clock wise. fit one if not already there, or swap with another if thtere to see if it has blow (if you can't identify weather it is or not)
  8. Wire
    Wire New Member
    Kadina, SA
    VR Exec 94
    i just checked then and it does have a fuel light, Awesome. 2 morow i plan to check to see if it has/ blown the globe, does anyone have or know of a simple guide on how to do this? thanxs
  9. pyro_104
    pyro_104 Member
    VR Executive
    I have a series 1 VR exec and when I took my instrument cluster out on the weekend (to replace the odometer gear... great howto btw) I noticed that there is no globe in the low fuel position - just a white circular sticker over the hole.
    Now it's probably a good thing that I found this out because I have run my car quite low before and assumed it had a warning light (because I saw one in the past on a VR... althougth that might have been a higher spec car).
    So the question is - is the bulb just missing (i.e. if I replace it will I have a functioning warning light) or is there no fuel sensor at all on the executive?
  10. kopper69
    kopper69 New Member
    VRII Acclaim
  11. Charg'd
    Charg'd New Member
    in a ford
    ford
    i had this issue with my vr exec s1 later found out it never had one
  12. pyro_104
    pyro_104 Member
    VR Executive
    When I went in to replace the odometer gear I also soldered in a globe (there was no holder for the bulb, but there was exposed copper terminals on the circuit sheet) in the low-fuel light position. Guess next time I'm running really low I might find out whether it worked or not. Is there a separate sensor or limit switch in the tankto activate this warning? I suppose what I should do it trace it back to it's origins and see whether there's a sensor to set off the warning.
