damm little beepy thing.
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Haydz, Dec 21, 2007.
  1. Haydz
    Haydz Fasten your seatbelts
    Liverpool.Sydney,NSW
    VS UTE LS1 T56
    hey guys well since i fixed the major problem with the wiring loom. i have been getting a sort of tune from my car.
    i have read the handbook and it says that it should play an "audible warning" when:
    *The Handbrake is on and the car is moving
    *You have exceeded your set speed
    *The engine is overheating.
    thats all i can remember.
    i know its not a loose wire because it still happens on the smoothest of roads well thanks for all your help guys.:bow:
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Also should do it for low fuel - if you still have the original owners handbook there will be a list there - I've got a VS Exec which is different to the VR Berlina so can't help you there.
    The handbrake one is the major cause of chiming as the switch get misaligned easily and the brake handle sometimes fails to fully return. Good Luck.
  3. dufus
    dufus Donating Member
    rickshaw
    If it is the same as my VR you will also have a low fuel warning chime. As Hako has already said check that your handbrake switch is properly aligned.
  4. TheForgotten
    TheForgotten only human......
    quarantine
    VR EXEC
    if your car has an airbag, it will also have an alarm for a faulty airbag circuit
  5. Haydz
    VS UTE LS1 T56
    oh yeah and i also get a code 48
    not sure if that helps
  6. TheForgotten
    quarantine
    VR EXEC
    48 = crankshaft reference signal missing. the car shouldn't be able to run, so i'd say that's a dodgy code
  7. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    That's strange - my Gregorys says 48 = no cam angle sensor signal....and this would make more sense as I think the engine will still run but the engine light will come on.
  8. Haydz
    VS UTE LS1 T56
    well the car rums perfectly
    does anyone know where the little speaker is so i can disconnect the bloody thing
  9. TheForgotten
    quarantine
    VR EXEC
    I thought 48 for CAS was strange when I checked. my code reference sheet isn't from the manual, it's off this site, and there's 2 codes for a crank angle sensor, so one could be wrong
  10. TheForgotten
    quarantine
    VR EXEC
    under the dash is about as specific as I can get. shouldn't be hard to find, it's a regular piezzo speaker like the horn but smaller. might be best to have it checked by holden just in case, as I'm sure the whole system utilizes the one speaker
  11. VZTHUNDER
    VZTHUNDER Enhanced Custom Tuned
    SA
    VZ SS Thunder MY06
    on my vx its on the back of the cluster
    tho im not sure if the VR is different
  12. dufus
    rickshaw
    Why dont you find out what is making it beep and fix that instead of just disconnecting it. Those beeping warnings can be extremely useful.
  13. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Try checking the cam angle sensor - either the wiring or the unit. That code 48 is your best clue.
  14. Haydz
    VS UTE LS1 T56
    just how am i supposed to check it thanks guys any help is appreciated
  15. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Gregorys just says remove and check with no test procedure. What I'd do is remove but do not disconnect - run engine - disconnect - run engine again and note any difference. If there is a difference then that means at least it is connected - if not then maybe it is not connected/wired so that its signal is getting to the ECU.
  16. Haydz
    VS UTE LS1 T56
    well the funny thing is. i don't have a cam angle sensor! dont know how that works but yeah. and its running perfectly now took the dash apart and checked all the wiring and no more beeps. so im happy thanks for the help guys
  17. Haydz
    VS UTE LS1 T56
    well problem is fixed and i found the speaker. its inside the instrument cluster (level 3) dead in the centre if anyone was interested.
  18. Joey_21
    Joey_21 New Member
    Western Suburbs
    VY SV8 HBD---mmmm LS1
    mine does this every now and then if its ur handbrake
    i jusat usally rip the hand brake up obviously while cars turned off just rip it up so it makes the clicking sound without using the button seems 2 fix it til next time lol
