Damn button on park brake.............
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by blackallite, Oct 8, 2008.
  1. blackallite
    blackallite New Member
    vp commodore
    Looking for a roadworthy for my vp commodore today and the damn button is stuck in and won't catch. I need pointers as to how to access the button please!!!:cry:
  2. DavoVP
    DavoVP New Member
    You can lever the button completly out, the mechanism still work's. Its spring loaded so have a hand infront of it to catch the button and spring.
    Mine did the same thing and my button just flew out when i was playing with it. Im not sure if it can be road worthy'd but i dont see why not as it still works the way it was intended.
  3. Turd Ferguson
    Turd Ferguson Donating Member
    N.S.W
    Disco
    mine gets stuck in sometimesd, usually moving it around a bit works. either use your finger or get like a small screwdriver to try and move it around.
  4. centy
    centy Member
    Vp series 2
    just unbolt and replace.
    take console out and undo cable underneath then the 2 bolts near passenger seat and the whole thing comes out.
  5. pow3rslave
    pow3rslave DoNothing Member
    eastern subs, vic
    VP 5.0L
    mine got stuck a couple of times, but i think i was mucking around and probably deserved it, i gave it a sharp rap with a screwdriver handle and it popped back to where it should be
  6. Ado
    Ado Are we there yet?
    vsII statesman L67
    If you manage to free the button by levering it out try CRC and work it in and around
    the button itself once you've freed it up use something similar to a spray grease to further and continue lubricating the button works in most cases see how you go otherwise u may need to replace the button assy
  7. Lost_Pete
    Lost_Pete Member
    VN Wagon
    My button mushroomed at the end from use and that is what caused it to get stuck. The button just pulls off (you might have to use a screwdriver if it is really far in) and a replacement one from Holden is a few dollars. Just pushes back on.
  8. VN_Luke
    VN_Luke ƃuoɹʍ ʇsnɾ sı sıɥʇ
    Mexico
    Get in the ute
    this happened to me a while ago too!
    It works awesome as a 'rally' style handbrake! .... then you get used to it, enter a corner on the handbrake and find that it gets stuck in the 'up' position because the button decides to work again :p
