dash lights come on
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by System, Feb 6, 2008.
  1. System
    System Donating Member
    2005 VZ commodore exec
    ok well every now and then (hasnt done it for a while) [i have a 93 VR acclaim] the 'low battery' and the 'no abs' light would go on, then after a while it'll turn off again... now i dunno if this was linked at all- MUST have been a coincodence, i had the air con on the last time- its not workin too good, the lights flicked on, i turned the air con off- and the dash lights turned off... can anyone help me out please? :D
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Its possible your battery is either on its last legs or needs a good charge. Most VR/VS Commos need a good battery otherwise strange things can happen. Another thing to check is the alternator which may have worn brushes giving intermittent/low charge.
  3. System
    aah right now, the terminals r pretty beaten up- i plan to put a new set in asap... but of course like always other things get in the way haha, that may be why the lights do that :D cheers i'll let ya'll know l8er on when i actually get it done! lol
  4. VRSS
    VRSS New Member
    Radelaide
    VX Clubsport R8 6-Speed
    tighten your terminals, i had a real loose battery terminal and the same 2 dash lights you speak of used to flicker on and off. then one day i went outside in the morning and my car wouldnt unlock or start, cleaned & tightened the terminals and it was fine.
  5. System
    cool thanx for the help i'll get that done tomorrow :D
