DashCommand - OBD-II gauge dashboards, scan tool, and vehicle diagnostics
IceyAUS
SA
VE SSV Series II Sedan
*** NOTE, I DO NOT WORK FOR THEM ***
App Shopper: DashCommand - OBD-II gauge dashboards, scan tool, and vehicle diagnostics (Sports)
Great little iphone/ipad app, Down from $59 to $23.
Get while you can for this price. Not often this goes down in price.
Description
WANT GAUGES? This is the app for that. DashCommand is the ultimate OBD-II vehicle instrumentation application available for the iPhone, iPad, and iPod touch. The built in dashboards can display a total of 27 gauges pulling data directly from your ride's engine control module. Also use DashCommand as scan tool to read and clear the trouble codes that caused the "check engine light" to turn on, a trip computer, or a race day companion.
NOTE: DASHCOMMAND REQUIRES A COMPATIBLE HARDWARE INTERFACE, PURCHASED SEPARATELY, SEE BELOW.
--- SEMA Show 2009 1st runner-up for best mobile electronics product.
--- Winner of 9 Global Media Awards at SEMA Show 2009
Get the benefit of multiple gauges without the overwhelming clutter and the expense!
Performance gauges:
- engine speed
- corrected vehicle speed
- open/closed loop *
- boost/vacuum combo gauge
- acceleration (and braking)
- power with optional drag correction (air & tire) **
- torque **
Fuel economy gauges:
- inst. fuel economy ***
- avg fuel economy ***
- avg fuel economy over 3 time periods ***
- distance to empty *
- time to empty *
- fuel level % *
- fuel remaining in tank *
- fuel flow rate gauge
Engine gauges:
- timing (spark advance) *
- engine coolant temp. *
- intake air temp.
- ambient air temp. *
- manifold absolute pressure
- mass air flow
- fuel trims, short and long term *
- percent engine load *
- catalyst temp. *
- fuel pressure *
- lambda gauge *
- air/fuel ratio *
* Requires that the vehicle supports the underlying parameter.
** Requires vehicle settings values.
*** Fuel economy for Diesel vehicles is experimental and may require more time to calibrate
DashCommand also contains a sophisticated trip computer that maintains 41 stats for 5 trips, custom A and B trips, Today, Previous Day, and Fillup.
- distance travelled
- fuel consumed
- avg fuel economy
- fuel cost
- elapsed time
- drive time
- average carbon dioxide emission rate
- total carbon dioxide emission
- start date & time
- number of fillups
- avg fuel flow rate
- avg driving speed
- avg trip speed
- avg boost/vacuum
- avg engine speed
- max acceleration
- max engine power at wheels
- number of stops
- max fuel flow rate
- max speed
- idle time
- max boost/vacuum
- max engine speed
- max braking acceleration
- max engine torque
- % distance travelled while not in gear
- % distance travelled in each gear
- % distance travelled in non-optimal gear
- % time spent while not in gear
- % time spent in each gear
- % time spent while in a non-optimal gear
Additional Features:
- Professional skidpad showing lateral and accel/braking Gs with min/max indicators
- Race track visually maps out your location, acceleration and braking as you drive laps around the track allows you to visually analyze different race track laps to see how acceleration and braking changed from lap to lap thus helping you to improve your lap times on your next outing.
- Inclinometer shows rolling angle and vehicle pitch for off-roading.
- Full support for OBD-II diagnostics, find out why your check-engine light is on and clear diagnostic trouble codes (DTCs)
- Data logging, record and playback log files showing OBD-II data and skidpad/race track data simultaneously
DISCLAIMER: DashCommand requires the purchase of a compatible third party hardware interface to communicate with the vehicle's OBD-II port. The Skidpad, Race Track, and Inclinometer do not require OBD-II data and are fully functional without any extra hardware. An iOS device with GPS is required for Race Track mapping.
DashCommand supports all OBD-II and EOBD compliant vehicles sold worldwide.
Hardware compatibility:
- ELM compatible Wifi (OBDLink, PLX Kiwi Wifi +iMFD, OBDKey WLAN)
- Innovate Motorsports OT-2
- GoPoint Technology GL1
Visit the DashCommand product page for more information:
DashCommand - Palmer Performance Engineering, Inc.
And i got my hardware from this guy... http://www.ebay.com.au/itm/PLX-KiWi...=AU_Car_Parts_Accessories&hash=item45f6f415fa
Turd Ferguson
Donating Member
N.S.W
Disco
If you are cheap and want basic stuff. android has one called "Car Dashboard" which has gps based speedo, max speed, current elevation and location. theres a pro version of it also but that costs monies.
adam_4049
2011 VE Series II SV6
When did the price get dropped?? It still says $$59.99.
oska
vx custom 600RR
innovate give you the app for free
i made the mistake of thinking my vx v6 was ODB2 so i bought the wireless equivalent and of course it doesn't work .. soon to be on sale
it's only the V8's from 1998 and VE onwards commodore that are OBD2 compliant
all V6's are ALDL or ODB1+ holden own diagnostic link interface = tech 2
timofay
Ringwood, Vic
VE SV6 Ute
So does
eBay Australia: Buy new & used fashion, electronics & home d
work with a VE SV6 S2??
Torquative
Sports Economy
VE SV6 3.6L SIDI 6sp
Alloytec are obd ii as well
aza03
ve series 2 ss
Hi does any one know of an andriod app like this that will work for a vy v6
Jezza
Now with LS1 power
South Australia
WH Statesman International
while the vy has a obd2 plug it runs different software and the app i know off doesnt work with my v6 vy but it works on the v8s as they do run obd2
oska
vx custom 600RR
don't make the mistake i made holden didn't go OBD2 on the V6 until the alloytec
what you have is ALDL (Assembly Line Diagnostic Link) or OBD1
