Dead battery, how to pop the boot?
bwian
vs s111 ute 3.8
Was flat, now is dead flat with no ignition (lights were tested and left on) Cannot do anything and the battery is in the boot.
How does one access the battery or pop the boot without power?
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
put the key in the door and open the car.
Pop the bonnet and attach a charger to the engine bay terminals (or jump start to charge it)
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
There’s an emergency boot release on the drivers side of the “ski port” in the rear seats. Fold down the middle seat in the back and theres a ring pull for the boot halfway up on the drivers side of the hole going into the boot.
bwian
vs s111 ute 3.8
Cheers. I will try both tomorrow. Not my car. Kudos Just Commodores forum.
losh1971
North Tas
VE Series I SS Ute
If it's not your car, don't try and jump start it. Just charge up the battery and see how it goes. Occasionally jump starting a VE can cause expensive problems.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
"Pop the boot".... ;)
Fu Manchu
WA.
Yep,
• unlock the door with the key.
• Open the rear door.
• Fold down the arm rest in the centre of the rear seat.
• Pull the yellow boot release.
• Get out.
• Open boot normally.
• Remove the Negative terminal first.
• Then the positive terminal.
• Then remove the battery.
• Then charge the battery.
• Reinstall the battery.
• make sure the vent tube goes back on. (Really important)
• Then attach positive first.
• Then negative terminal.
• Start car.
