dead spot in accelerator can this be adjusted?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by daNc, Nov 26, 2011.
  1. daNc
    daNc New Member
    VX Berlina II
    Hey, on my VX i can push the pedal down an inch or a bit less and it wont do anything, wondering this is normal and if not, can it be readjusted? also when i have to brake i cant just roll my heel i have to actually move my leg back and then put my foot on the brake because the brake pedal comes out more then the accelerator, can this also be fixed?
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    You can adjust the throttle cable where it connects to the bracket on the throttle body.
  3. daNc
    daNc New Member
    VX Berlina II
    Ok thanks, i wouldnt have a clue how to do that and is this fix for the dead spot or does this bring the pedal back a bit for easier braking, and im guessing its not normal how it is at the moment? thanks
  4. accentstencil
    Eschol Park, Sydney
    Hopefully both. If you look at the bracket where the throttle cable connects to the throttle body (in the engine bay not the accelerator end) you will see that it is threaded where the inner cable goes through. Undo the nuts and adjust to increase the tension, if you go to far you will increase the idle, so be careful
  5. daNc
    daNc New Member
    VX Berlina II
    thanks for the help accent, also u were helping me a while back about how my windows fog up and said about the AC drain hose being blocked maybe, i would like to check this but dont really know what im looking for, do you get to it from the top of the car or the bottom? im not sure what im looking at/for, thanks again
  6. accentstencil
    Eschol Park, Sydney
    You get at it from underneath the car, above the front of the transmission. You are looking for a short piece of hose coming out of the floor, a bit more towards the passenger's side if I recall correctly, it will be easier to see with a torch. When you find it, stick something like a long cable tie up that hose to clear any debris. If it was blocked water should run out. Avoid sticking any sharp objects up there.
  7. daNc
    daNc New Member
    VX Berlina II
    ok im not exactly sure where the transmission is lol, im only new with cars and would a pen be long enough to stick in there?
  8. accentstencil
    Eschol Park, Sydney
    The big thing bolted to the rear of the engine is the transmission.
    You are looking a the area just behind the cigarette lighter socket in the console but from underneath the car, sort of in line with the front of the front doors. You have the flat area of the floor, driver and passenger side and in between that you have the have a space where the transmission sits. Look in there.
  9. daNc
    daNc New Member
    VX Berlina II
    Ok thanks, very helpful hopefully i get a chance to check it later today
