Pete O
- Mar 8, 2019
- 86
- 11
- 8
- Age
- 68
- Location
- Meringandan
- 1990 VG ute
"started it again & it didn’t want to run, kept dying when i touched the throttle" that's not the IAC. A bad IAC will cause high idle after a high speed run because it can't reset to the required low air flow. Your problem sounds fuel related but if you try another IAC make sure you retract it enough (surface of the valve to the tip of the pintle less than 28mm) when you install it and either set it by running the engine at 2500 rpm for at least 20 seconds-in the garage or driving around.
Oh ok, didn’t know about setting the height, I just took it out of the box & threw it in. I guess I’ll have to take it out now & set it properly?
