Decicrate
Would love to see this "skin" that you're getting done! As I know my sc gets that hot that you can hardly touch it!
I should have an answer next week from the welder if it is possible or not, if so I will start to make the "skin" straight away.
Basically it will be a box that goes from the bottom of the blower near where the mounting bolts are, and up and over the top where the ribbed section is and down the other side to the mounting bolts. It will sit about 3MM off the existing case with a twin entry on one side and a duel exit on the other.
It will be feed by a davis craig 19ltr per minute water pump.
If the welder says yes I should have it done within a couple of weeks and I will post some pictures of the finished product.
Really hoping that they can do it, be very disappointed if they can not.
