Decicrates VS L67 T56 'S' Pack
Decicrate
BrisVagus
VS L67
Well some more bits have been added to the new build. I am getting a set of these babies to help get better fuel control.
These have the best spray pattern that I have ever seen for a large injector (100Lbs)
attachment.php
Decicrate
BrisVagus
VS L67
Well my new blower elbow from adz turned up. So it was a day of match porting and a bit more internal blower porting. Have to say the elbow is a pretty big unit!!!! It should be able to flow bucket loads more air!!
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Raptorsc
RAPTR6
Cairns Qld Australia
www.raptorsc.com.au
Hilux 4.0 V6 SC 400kw
attachment.php
Deci
What's the price of these injectors?
Is Moran the manufacturer?
adz_vy
VY Spac l67
Looks awesome can't wait to see this thing in action.
Barry you may need to grind down that small vac fitting some more to make it thinner. The thinner ones are 3mm and very weak. Also rare.
Decicrate
BrisVagus
VS L67
Deci
The cost is $188.00 (USD) per injector. These babies are not cheap!! I am waiting for them to get back to me with a complete price. You need to run a 10 micron filter when using these puppies or they will not cover your warranty. These would have to have the best spray pattern I have ever seen with a high flow injector.
The tips also sit into the runner so you get a better air/fuel mix. The range from 100Lb to 500+Lb.
https://www.moranmotorsports.com
Decicrate
BrisVagus
VS L67
I am surprised it was still there!! Stupid Aus post left it sitting at my front door on Friday, I had Friday off and was in Sydney for the week end, got to work this morning and here it is soaking wet at the front door. Bloody fools!!!
I will just use a larger piece and a step down to get the vacuum hose to fit.
Unfortunately the pictures don't give a true representation of how big this thing is!! You can almost park a car in there!!!
Hopefully it will help push the power figure up a bit more!!
39
NSW
VY 1 Tonner S V6 Raptor Charged!
What power gain are you look at or hoping for with the new mods mate?
Decicrate
BrisVagus
VS L67
Would like to see about 15 to 20 at the wheels.
Decicrate
BrisVagus
VS L67
Well I wasn't quite happy with the blower porting that I had done, so after another 3+ hours of die grinding this is the port that I am going to run with,,, I think,,,,,
attachment.php
Decicrate
BrisVagus
VS L67
Well not much more has happened, the new resistor pack arrived for the injectors that I am still waiting for.
attachment.php
I also CC'ed my combustion chambers so I can now make them all the same. Seeing the amount of work that I have done to these I was very surprised at how close they actually were.
No.1= 61
No.2=60
No.3=61.9
No.4=61.2
No.5= 60.7
No.6=60.5
Well back to some die grinding for me!
