definitions for vs or newer ?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by ragex, Nov 22, 2006.
  1. ragex
    ragex New Member
    does anyone have definitions for vs and newer?
  2. holden#1
    holden#1 New Member
    Maroochydore
    VS S1 Executive V6
    1995 on????
  3. ragex
    ragex New Member
    yes thats right
  4. kopper69
    kopper69 New Member
    VRII Acclaim
    What sort of definitions mate? Size/weight/power etc? (Gotta be a bit more specific)
    If so, rebook.com.au is what youre after. This link should take u right to it:
    http://www.redbookasiapacific.com/au/vehicle/index.php?make=HOLD
    When you find the car, click on specifications. It has everything
    This is what my VR acclaim has:
    Standard
    Equipment 4 Speaker Stereo, ABS (Antilock Brakes), Adjustable Steering Col. - Tilt & Reach, Airbag - Drivers, Central Locking - Remote/Keyless, Cruise Control, Independent Rear Suspension, Power Door Mirrors, Power Steering, Radio Cassette, Tacho
    Optional
    Equipment Air Conditioning, Limited Slip Diff, Power Windows - Front & Rear
    Release Date 7
    Body Style SEDAN
    Badge Acclaim
    No. Doors 4
    Seat Capacity 5
    Series VR
    VIN Number 6H8VRK19HPL######
    Drive Rear Wheel Drive
    Transmission 4sp Automatic
    Gear Location Floor
    Engine Size 3791cc (3.8)
    No. Cylinders 6
    Engine Configuration V90
    Cam Pushrod
    Valves/Cylinder 2
    Compression Ratio 9:1
    Engine Cycle 4 Stroke
    Engine Type Piston
    Engine Location Front
    Engine Number VH-######
    Fuel Type Petrol - Unleaded ULP
    Fuel Capacity 63L
    Fuel Consumption Urban 12L/100km
    Fuel Consumption Extra Urban 7.6L/100km
    Fuel Delivery Multi-Point Injected
    Method of Delivery Electronic
    Induction Aspirated
    Power 130kW @ 4800rpm
    Torque 295Nm @ 3200rpm-3200rpm
    Kerb Weight 1347kg
    Tare Mass 1347kg
    Wheel Base 2731mm
    Length 4861mm
    Width 1794mm
    Height 1448mm
    Track Front 1491mm
    Track Rear 1491mm
    Country of origin AUSTRALIA
  5. jc58nc
    jc58nc Guest
    He's talking about definition files to tune the Memcal in the ECU.
    Vs onwards is still in the hands of Holden and their dealers/tuners and is not public domain like Vn Vr.
    In time it may become available, but not at the moment.
    I have sent copies of all the Vs v6 bins I have to Tunercat in the US to see if they can crack it. You can work out the main tables fairly easy but it's all the one byte constants and flags that are hard.
    If anyone sources the full $51 definition for Vs v6 I'm prepared to donate some funds towards it's purchase.
  6. jc58nc
    jc58nc Guest
    Ragex empty your PM bin it's full :bang:
  7. greenfoam
    greenfoam New Member
    VP Executive R-spec
    Ive never had the V6 binaries to compare them but I don't think I'll stress over it unless I have a VS :)
  8. ragex
    ragex New Member
    done lol.................
