Delay in front window winders
Rastawayne
62
2000 vx v6
I have recently bought a vy crewman ss , the front windows seem to have a 5 second delay when I go to wind them down, if I keep tapping the switch they go down immediately but only in small increments, if I hold the switch there is a 5 second delay, if I lift my finger off the switch it's another 5 seconds before they will wind down. It's both front windows, the rear windows are fine , seems a bit strange that both front windows are the same . I have changed the main switch in the console but no different. Any idea's,? cheers
Jezza
Now with LS1 power
South Australia
WH Statesman International
It's a issue with the BCM and the auto down function on it. I'm not sure on how to fix it other then having to replace the BCM.
I ended up just dealing with having to hold the button down for a bit longer to have it manually go down as I replaced the BCM and within 6 months it happened again
