Delcowizzid'a vn gts-t
Discussion in 'VN - VP - VG - VQ' started by delcowizzid, May 20, 2010.
  1. VN_Luke
    VN_Luke ƃuoɹʍ ʇsnɾ sı sıɥʇ
    Mexico
    Get in the ute
    ........ I am speechless - and I applaud your motivation.
    but, I will say.... just FYI... that it cost me roughly 50 bux to get an exhaust mani flange laser cut out of 8mm steel.... materials included.
    ... additionally - any reason you didn't make a tall rocker cover from two normal rocker covers? :p
  2. immortality
    Sth Auck, NZ
    i think my cheap ass $25 jigsaw would do it. with the correct fine tooth blade. the trick is to spray some CRC5.56/WD40 on it occasionally to stop it heating up and gailing/binding.
    LOL, labour costs are to high here in NZ unless you know somebody. a local place wanted to charge me $50 to weld on a bit of alloy to my inter cooler piping for the BOV :(
  3. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    haha cheers luke definately wont be going into mass production thats for sure LOL. just 2 weeks left before the drags and they need to be in and tuned running out of time.shes getting a quick tickle up at 14psi on the street tomorrow then we are dropping the exhaust fitting the headlight CAI new diff with better ratio and filling it with avgas might even tune it too 18psi this time going to measure exhaust housing backpressure readings before and after exhaust as well must be getting up there by now
  4. delcowizzid
    NZ
    в∞ѕтεכ √&
    we have a cheapo LOL XU-1 brand but all the blades we could buy only reach halfway through the billet when the jigsaws on full retraction of the blade it pokes out through it at full extension no worries.next one i might just cut the whole thing with the 1mm cutoff wheel instead of drilling holes may work out lots faster it took ages to drill 107 holes in that solid alloy hahaha
  5. VN_Luke
    Mexico
    Get in the ute
    When you say "housing backpressure" do you mean pre-turbine and post turbine pressures?
    I'd be reallllllly interested in a graph of pre->post housing pressures vs intake mani pressure. (with and without exhaust.. too)
    I'm planning on running a coil of copper wire off the merge collector and then into a map sensor on my car so I can measure backpressure. (the coil is there to cool the gasses so they don't melt the guts of the map sensor)
  6. immortality
    Sth Auck, NZ
    i just measured mine. at full retraction the blade sticks out 35mm. fine tooth. go to bunnings and have a look for some blades man. save yourself a lot of hassle.
    i'd just drill holes in the corners. use a cut of disc for the straight bits and jigsaw for the twisty stuff
  7. delcowizzid
    NZ
    в∞ѕтεכ √&
    hmm bunnings it is cheers mate will be way easier.
    luke ive been meaning to measure the pressure in the exhaust manifold for a long time i have a fitting in the number 1 runner just before it joins the log for my EGT sensor ill screw it out and fit a metal standoff to a boost gauge for now but i do plan on fitting another map sensor for logging purposes later if the exhaust is restrictive at our power levels we should be able to lower the pre turbo back pressure by dropping the exhaust we only have hotdogs in the 3" pipe but 2 of them are fluted hotdogs with the raised ribs in the airstream these may cause a loss of flow its the little bits of research like this that may get us good gains.after march if we get a 10.99 and get told we need a cage its time for some heads to make up for the weight of the cage.then when we cant go any faster we will fit some tuned length manifolds or a twin turbo setup on tuned length manis and get a more aggressive cam
  8. delcowizzid
    NZ
    в∞ѕтεכ √&
    VB just got a mention in petrolhead magazine for the second time last time was for the masterton burnout comp :D
  9. delcowizzid
    NZ
    в∞ѕтεכ √&
    went out tuning the VB today lasted about 10 minutes then we were getting low on fuel time to pull over and slap in the 20L of 110/130 avgas and a few degrees timing :D lasted 5 mins before twisting the diff till oil pissed out and then blowing another T5 think them roller rockers and av make a big difference LOL this diff has been in and out of the car over time and has never made a noise but withen a minute was starting to howl as the diff tweaked out of alignment then the horrible smell of gear oil burning on the exhaust filled the car man we havnt even dropped the exhaust or fitted our CAI headlight yet new T5 is in allready :D feels way faster than before january drags getting excited and the smell oh buitiful lead avgas smell gotta love that turbo loves it posting pics soon of what lead looks like on a turbine wheel and exhaust valves
  10. delcowizzid
    NZ
    в∞ѕтεכ √&
    hmm rich as 10.5-10.8 totally no soot huge torque and power must be the ashless avgas normally run at 11.8-12 on pump gas and pull out my wideband and it has soot on it
  11. immortality
    Sth Auck, NZ
    Hmmmmmm Avgas. gotta love the stuff. my V8 always ran heaps better with some in the tank :D don't let the cops catch ya with that **** on the street though.
    time to set up a memcal with switch-able tunes. then try some E85
  12. immortality
    Sth Auck, NZ
    Where exactly are you twisting the diff housing? might have to weld in some re-enforcements
  13. delcowizzid
    NZ
    в∞ѕтεכ √&
    new streamlined exhaust on :biggrin: just needs a rubber hanger and shes ready to go
  14. immortality
    Sth Auck, NZ
    Sound clip :D
    thats gotta be loud. don't get caught on the road like that:cops:
    howz it spool now?
  15. VN_Luke
    Mexico
    Get in the ute
    Any normal person would have stopped driving when the diff oil started leaking lol.
    top effort! can't wait to see measurement of how much it's gained!!
    Whatsup with the colouring of the turbine/valves? - is it jsut from running mass hotness with no soot/rubbish to cover them?
  16. delcowizzid
    NZ
    в∞ѕтεכ √&
    the turbine wheels and valves are clean from the cleaness of ashless avgas and the coating of lead thats left over those pics were running grossly rich 10.4:1 no soot there :p avgas is great stuff
    welllll did the exhaust and CAI make a difference hell yes LOL dropped the fuel ratio 1 whole point 10.4 yesterday with exhaust and engine bay pod 11.4 today straight off the bat its dangerous now rips the tyres off the road the moment boost hits and holds it to the limiter nasty axle tramp at high speed was funny as bring on the drags
    YouTube - 19 07 08 0826
    YouTube - 19 07 08 0648
    YouTube - 19 07 08 0646
  17. delcowizzid
    NZ
    в∞ѕтεכ √&
    what the tyres look like after 15 minute tuning session LOL no burnouts on them
    high tech CAI yes we cruising with no headlight LOL
  18. soop
    soop Banned
    Smithton, Tasmania.
    2003 SS Commodore Series II
    Looks like the tyres were down to the indicator to start with.
  19. delcowizzid
    NZ
    в∞ѕтεכ √&
    cause it gets fed $10 tyres cause it can kill new ones in a 5 minute drive we were being nice to the new T5 today LOL but new or old they allways come home with big bits missing and no good :D
  20. delcowizzid
    NZ
    в∞ѕтεכ √&
    thought i better take a look at a log from todays tuning seems 60lb injectors are maybe not gonna last long they are at 79.6% DC
