Dented Engine Oil Sump. Help!!
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by lazza44, Jan 31, 2008.
  1. Tom_1569
    Tom_1569 Ecotech Power
    Gippsland - VIC
    '14 SR5 Pusslux
    Should be using HPR15 not 30, according to Penrite themselves, we have 15 in our VN and it runs perfect, not any foreign noises.
    Penrite Recommendations
  2. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    i have hpr 30 in my vn so does me parents vn and me sisters vp and mates vs and haven't hap a prob with it...neither know they recommend hpr 15. In fact the guy at super cheap said that they (penrite people) recommend hpr 15 but he said that hpr 30 is the stuff every vn-vs owner going in there, is putting in there car...a little thicker but these engines are getting on in age and need it...plus i don't think it would cause the engine to knock...i think there is some bearing damage or the oil pick up is clogged
  3. Tom_1569
    Gippsland - VIC
    '14 SR5 Pusslux
    Yeah, I agree, shouldnt be causing a knock, though could cause a tick at the most.
  4. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    So long as your oil light isnt coming on(low oil pressue) and there isnt any significant leaks anywhere you should be fine...
    Mine has a massive dent in it too... i think that it is a very common thing with the 'ol V6.
    aZk.
  5. lazza44
    lazza44 New Member
    VN S2 Berlina Wagon
    mine was actually a 20mm not a 30mm dent as originally stated. I have not fixed it and its been over 4 months so i think I'm in the clear. If your a good welder you could try welding a nut on and pulling it out with a large bolt...
  6. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
    Mine has a sump guard fitted :p can see where its saved it a few times
  7. jas98
    jas98 Active Member
    maryborough QLD
    haha yeh try dinting that :D
  8. timmy_tam
    timmy_tam New Member
    VN calais 91
    any chance of a picture of the actual sump guard? had a squiz on ebay, nothing there :(
  9. the executive
    the executive New Member
    Corio,Victoria (Geehole)
    88 VN 5spd 3.8
    mine stays on AAAHHHHHHHH
  10. Cheap6
    Cheap6 New Member
    VP Exec
    Perhaps something like panel beaters use to pull dents; a mushroom shaped thing like a washer on a stick could be used - soldered on. I think that welding might result in oil burning and scaling inside the (emptied) sump, soldering might allow the heat to be kept low enough. Applying the force against a piece of wood laid across the edges of the sump reservoir would avoid distorting the sealing surface.
  11. SweetWagon
    SweetWagon booosted
    Springwood NSW
    Yeh next time im under the car ill snap a pic for you, maybe weekend.
    Nothing interesting really though, just a big plate. Part of the V5W country pack, hence why my car used to look like a 4wd!!
