diagnostic mode
boily
vy berlina wagon
hi guys I am trying to get my vy series 1 to flash out some fault codes on the engine light. I have the manual but the terminals in the book don't match with the one in my car the diagnostic test terminal isn't there any help will be appreciated.thanks
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
It should look like this and will be under the dash, below the steering wheel.
Trust me....it'll be there.
Short together terminals 5 and 6 with a paper clip or a bit of thin wire.
Use a torch, as it can be a bit hard to see sometimes, where to insert the wire.
boily
vy berlina wagon
I have taken a photo of mine see what you think.
thanks
statey1975
WK Statesman
Ummm....I didn't think you could pull this trick on a VY??
TazzI
Envyous Customs
Western Australia
www.envyouscustoms.com
Holden VE SS Ute
thanks
Yep thats the one. Although your going to need an ALDL cable to actually read out the codes.
Yeah same, I only know about getting the faults using a proper diagnostic cable.
RSTEP
VY 2002 Stock
I dont know if this would help buy you can view some trouble codes by
1: Pressing and Holding down the 'Mode' and 'Set' buttons while you turn the ignition on
2: Cycle through the different display and you can view a bunch of trouble codes there.
it is the second last menue item before the Dash test function.
RSTEP
boily
vy berlina wagon
it's ok I brought a diagnostic tool I'll see how that goes thanks for the reply's.
