bevzan
- Nov 24, 2011
- 77
- 46
- 18
- Age
- 54
- Location
- Redcliffe
- VS Ute
Trying to set tdc on VT sequential dizzy. dizzy is only used as signal for ls2 coil packs running wasted spark. It doesnt use the rotor button and that part of the shaft has been machined down to fit blank cap.
Timing marks on crank are set to 0 tdc (on compression stroke)
Does the square mark on the dizzy wheel represent tdc, because with a stock vt dizzy the rotor points 180 from the square mark. cant afford backfires as its lpg.
355 stroker
eaton m122
lpg sequential injection 16 injectors
8 x ls2 coils (wasted spark)
profire T ecu
355 stroker
eaton m122
profire T ecu
