diff/axle questions
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VL Berlina 5speed, Dec 10, 2008.
  1. VL Berlina 5speed
    VL Berlina 5speed Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    well the vs seems to have a really irertating noise coming from the rear
    it sounds the same as a wheel bearing (constant hi pitch squeal)
    so i was thinking axle bearings but when you touch the brakes it disapears....
    2 weeks ago i changed all the pads and check over everything on the cars brakes and all seem fine,
    for the past 3 years the diff has had bad backlash but we couldnt really care as it was a daily
    would backlash cause a bearing to go premature?
  2. ephect
    ephect Donating Member
    VS Acclaim V6
    normally when a wheel bearing is on the way out, it will more sound like a whomp, whomp whomp.. it will appear louder when turning one way and should almost disappear when turning the other way
    is she live axel or irs?
  3. VL Berlina 5speed
    yer it wasnt as noticable a few weeks back, more so a on off on off every second
    now its more quicker so almost sounds like its constant
    today perants went out and did a few hundred ks on a highway and its alot more noticable now
    live axle
  4. shanhsv
    shanhsv Luvo
    Muswellbrook, NSW
    VSII Calais V6 & VSII Senator 215i
    May need to take it out to get the diff checked,i had a very similar problem with my car,turned out bearings in the diff shat themselves,but this is in an IRS so it may the same problem it may not,sounds like it though
  5. immortality
    Sth Auck, NZ
    maybe pinion bearings. ahve you checked the oil level? has it ever been changed?
  6. VL Berlina 5speed
    well the car has done just over 400,000km now
    diff oil has only every been changed if they change it in the holden warrenty,
    we have never changed it since we have owned the car from 70,00ish ks
    suppose i should check if it has any oil in there lol
  7. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    brake guide pins need greasing.
