Diff Ratio 3.8
gsgib55
69
Liverpool
2004 VY SS Crewman ute 5.7 L
I now have 3.73 in my Crewman ute 5.7 , best decision since owning it , lower revs , amazingly smooth gear changes AND fuel economy of 32 mpg or 14 kms to the liter. Is there a ratio available of 3.8 to fit the Crewman or will I have to go to 3.9 , I find the 3.73 is just slightly slow off the mark owing to the larger size of the Crewman . If anyone should have a diff to suit Crewman with a ratio of 3.8 I would really like to hear from you . Garry
krusing
Melbourne, Bayside
Any Ratio can be used,[specified for Holden for that Series]
And it all depends on the size of the tires you are running,
Based on that, you will just need to alter PPK to suit the Ratio & Tire combination.
gsgib55
69
Liverpool
thanks for the reply , but I find it a little confusing , by what do mean 'any ratio can be used' ,
vr304
Auckland, New Zealand
2007 ssv manual
3.9 is the next one up from 3.73 mate, you could get a hi stall converter for getting you off the mark quicker and general better acceleration down low
Immortality
Staff member
Sth Auck, NZ
The common ratio's are 3.07, 3.46, 3.73, 3.9, 4.11
The difference between 3.73 and 3.91 is about 100rpm at 100km/h.
VYCommodore76
47
VY Commy
by common, he means these are the only ratios available. :)
gsgib55
69
Liverpool
hello , and thanks for the reply , would going to 4.1 over 3.9 be an option ?, garry
losh1971
North Tas
VE Series I SS Ute
Which trans do you have?
