Difference between carb cleaner and degreaser
matty88
LPG Installer :p
35
Doveton
TEXXXY: Resprayed TX3 Non Turbo
Whats the difference between degreaser and carb cleaner? Or can I just use degreaser and get the same results?
vlv8vic
<---Brad Quaid = internet stalker
Australia
M5
id imagine carb cleaner would haev something in it that would burn with the petrol rather than work against it. normal degreaser wouldnt do it any good. pressure pack stuff might be ok as it should be flammible.
matty88
LPG Installer :p
35
Doveton
so i should flammable degreaser or splurge on a new can of carby cleaner?
LowVp
VP Enthusiast
44
Dalby, Qld
VP Ute 3.8T T56
carb cleaner breaks down carbon build up, use according to purpose
K
Konker
Guest
and degreaser degreases (carbs)
lol best to use carb cleaner as it wont backfire and blow your air meter
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Carb cleaner also dries pretty clean and quickly as degreaser hangs around looking greasy
vlv8vic
Australia
M5
I dont know of a commodore with a carb and an air meter..... probably wrong though!!!
56
East Melbourne
3.2ltr car
ehhe
carb cleaner is a non residue leaving cleaning agent which doesnt need flushing. whereas the degreaser bacically needs some sort of water pressure to finish the job.
I would use someting like curcut board cleaner (which has simialr properties to carb cleaner, and Brakekleen) if wanting to clean airflow meters etc.
It can be a good idea to clean an airflow meter (hot wire one) if using something like a k&n filter as it can get oil residue over it effecting its role as an airflow monitoring device.
