You're welcome, thanks for the feedback! :yarr:
Do you think my Dec 09 built SSV SE L76 would have the revised lifters of the L77 ?
The easiest way to check whether your L76 engine* has the MY9.5 update with the LS3 manifold and TB is simply lift off the Turtle cover, look to see if the MAP sensor is bolted in like the one in
this video, which means it has the update.
[video=youtube_share;S986_UdNkh8]http://youtu.be/S986_UdNkh8[/video]
* I think I said
L96 engine in the voiceover (which is yet to be produced, LOL) of course I meant to say L76.
Btw What exactly is the" VF f/r track update" you have on your Black Pearl ?
Sure, it's widely reported that there is no difference in track / wheelbase between VE & VF V8s but in fitting four pot differential bore Brembos I realised that despite identical platform and similar weight between model variants there is quite a bit of flexibility in the factory setup re: track widths and Front / Rear stagger from VE SS to Gen-F GTS:
Front
VE SSV 1592mm
VF SSV 1602mm
VE HSV 1616mm
Gen-F 1622mm
Rear
Gen-F 1588mm
VE SSV 1608mm
VF SSV 1590mm
" " 1608mm
" " 1618mm
In other words the new model designation is staggered 30mm wider track at the front on the GTS, 30mm wider at rear on the SSV Redline from the factory. So I decided to set my car up within the dynamics of these parameters.
