I'd say the L76 would have the lower redline due to the gay lifters. I think the l77 got better lifters. My vz l76 stock tune won't let me rev past 6.
Anyway, waits for pirate :yarr: lol
Haha thanks but I've never seen the dash of an L98. What I can contribute is that my car is an auto and the dash has red marks starting at 6000 too. As far as redline being a recommended safety limit - the fastest, farthest, or highest point or degree considered safe - revving the engine past it's peak HP RPM with diminishing return and increased mechanical friction is possible but just because you can why would you want to do that?
All GenIV 6.0 engine variants officially hit peak HP at 5300 rpm, the L77 has been revised to 5700 rpm in some literature, however I personally doubt the veracity of essentially same engine achieving same output with same valve events at higher RPM. That's marketing, as it is flat-lining and there is no point revving the stock engine past 5300:
That's because with a stock GenIV 6.0 engine the Intake Valve lift to prevent choke at 5300 is .482, spot-on same as the cam, i.e. the stock engine begins to choke at 5296 RPM. Given at that engine speed the amount of air induction @ 28" is between 175 to 185 CFM, this equates to the engine's output - 270 kW and 540 Nm.
Yes there is a difference in the published redline between L98, L76 and L77 because of slight variance in the valvetrain. However since the world record holder runs a naturally aspirated L76 with AFM lifters in place and revs waay past that published redline, so is incorrect to assume that the lifters are holding back the engine from higher RPM or more performance.
FWIW I think the stock fuel cut-out is at 6000-6100 for good reason, increased performance from an unopened GenIV doesn't come through wringing its neck 5300-6100 (or beyond) without better control (safety) of the valve train and increasing the Trapped Ve%. With correct control and valve events plus usual bolt-ons you can rev reliably up to 6400 no matter which variant. You can rev past that (up to 7000) but you will need to open the engine and essentially rebuild key components.
