differential issue
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by mr_clubby96, Oct 1, 2008.
  1. mr_clubby96
    mr_clubby96 New Member
    vs clubsport
    hey guys im due to get my diff fixed i got a price rebuilt diff completely including diff oil and fitted $700
    im just wondering when they change ur internal gears
    cause apparentely u can get
    gears for better take off
    midrange gears
    and highway gears
    do they charge u extra for them ?? or does it included with the rebuilt of the diff
  2. Zuicider
    Zuicider Banned
    Stonedville
    Set of thongs
    4.11 ratio is good for quick acceration, crap top end and economy, yours is prolly 3.08 and they wont change the ratio on just a rebuild. 3.45 ratio is a good alround ratio
  3. Zuicider
    Zuicider Banned
    Stonedville
    Set of thongs
    better to get a good second hand gear set than to buy a new set
  4. mr_clubby96
    vs clubsport
    ah ok but my mate rekons it might no be the diff which is the problem cause this problem comes n goes the knock sound he rekons i mite have something loose where the tail shaft enters diff im gonna take it in to get it checked out cheers mate 3.45s or 3,55s gears will do the job
  5. Surfwagon
    Surfwagon Well-Known Member
    Sydney/NSW
    AMG Mercedes C63 Wagon
    If you do the diff then 3.45's are a great balance between cruising and acceleration.
    On the other hand check you tail shaft centre bearing (where the centre section of the tail shaft passes through a large rubber donut which is bolted to the body).
    The donut perishes and when you accelerate quickly or when taking off uphill the tailshaft bangs against the sides of the donut holder and because the bracket is bolted to the floor then it sounds like something knocking under the floor.
  6. mr_clubby96
    vs clubsport
    just exactly how u describe it is wat the issue im getting
    are they expensive to fix?
  7. Cobez
    Cobez LS-EXUAL
    2004 S2 VY SS Ute
    Geoff on here (Wagon Wheel) recently had 3:9's fitted into his manual VS Clubby, he said it did **** all, so maybe even shorter would be good. I'd imagine 3:9's would feel better in an auto though.
