jetspin_vn
JetSpin Racing Team
- Nov 13, 2003
- 1,430
- 8
- 0
- Age
- 39
- Location
- Mission Bay, Auckland, New Zealand
- VN GTS
I have had a look at the arm setup on my VS and thought that a hub change over should do the job but then i was told it is an expensive process due to the hub needing to be pressed out and with certainty the bearing will be damaged and need replacing. So my answer to this would be to get hold of a pair of VT control arms with the hub already fitted and replace them with my VS control arms but will the VT control arms bolt straight up to the VS cradle/frame??
I thought that i'd ask in my first reply about changing the whole diff because i quickly read that stealthy fitted a GTO diff into his VP which i think is quite original and awesome and it got me excited to think that hopefully there isn't too much mucking around to bolt a complete later model diff in because getting the parts are no problem as a good friend of mine owns a wrecking yard for late model Holdens.
I would prefer to change the whole diff to a later model as i could put in an LSD from an SS or HSV Clubby and such but which ever way works would be better than nothing as long as the brakes can be fitted safely.
If the VZ comes stock with an LSD, it can't be spooled.
VP-VSs IRS are the 7.5in
VT onwards are 8in (i thought it was 8.25, but it might just be 8)
VT s1 BW 78, 4-spider center, 28spline axles, 3.08:1 open and LSD (same as VN-VS)
