Diffs, FAQ
Kung-Foo-Kamel
Rockingham
Custom Hilux with a V6 Ecotec
I got some info on VZ V6 Diffs
7.5 or 7.6" not sure exactly
these only come in 2.87 and 3.08, they can be LSD or Open centre, this is it for the V6 diff, no other ratios available
I got a LSD 3.07 straight out of a VX SS and it went straight in to my VZ V6 Ute, bloody wrapped, so if anyone wants LSD in there VZ, VX and upwards fits perfect, after you upgrade to a V8 diff you can get nearlly any ratio you like :)
Hopfully this info helps someone out :) :thumbsup:
Wagon_Wheel
Drop A Patch....
Mt Martha, Vic
Got another quote today for $260 to swap the gears over or $330 to swap gears and do all the bearings as well. Which isnt tooo bad
bad-blue-dog
LIVE HARD, DIE HAPPY
Queensland
VY II CROSS 8 CREWMAN,VZ SS 5.7L,VP V6 Drag Racer
There is a drag meeting on at Carnell Raceway in Stanthope QLD on the 23rd August if anyone is interested in going head to head with my VP. It is only $50 to race and you get as many runs as you can fit in 5 hours. I often do 25 to 30 runs. Start time is 3PM, Finish at 8PM.
greenacc
Searching for the billion
VE Berlina
adding to the original post it mentions xd falcon diffs and ratio's. I've been told the S pack falcon wagon had a 2.77 ratio centre in it. My mate had one, i never saw the tacho go past 3000 revs ever.
XRUFFX
www.myspace.com
VT II LS1
question...spools, i was just guna buy one off ebay, good or bad idea? (in regards to buying one off ebay)
Wagon_Wheel
Drop A Patch....
Mt Martha, Vic
A spool is a chunk of metal, i wouldnt be worried about ebay brands lol. Just stick to a reputable seller in terms of acutally getting your item
bad-blue-dog
Queensland
Why don't you just weld the centre. It might sound a bit rough, but it wont break. Got mine done for $20.
STEALTHY™
So Wet For You!
SA - The Roadworks State
Sure, its $20 to weld it, but add on labour to pull the diff out, the spool basically pays for itself.
Welding = no!
Pub247
Melbourne S.E.
Ford Fairmont
An LSD centre out of a VT 5lt S1 clubsport garuanteed to fit and vn? I 99% sure it will but some reassurance would be nice before i go to put it in and find out it doesnt fit
