digi dash into vs ute
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by iloveutes, Jun 5, 2005.
  1. iloveutes
    iloveutes Guest
    guys,need help here.
    just got a v6 digi dash wanting to install into a v8 ute.
    1.does the v6 dash haveto be recalibrated to take the v8 readings(ie;tacho)
    2.has any one(or where can i get one ) got the patch harness ???
    does the patch harness include the wiring for the trip computer ??( I only have the speedo alert & it has a diff connector..thanks for your help
  2. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    V8 needs a v8 dash to work properly....tacho and temp gauge will not read accurately everything else is the same if you use a v6 one ...plenty of posts about level 3 dash installs ...do a search.
  3. Ute God
    Ute God Guest
  4. markovr
    northside brisbane
  5. Fekason
    Fekason Fekason
    Penrith NSW
    Modifications
    Hi,
    It is possible to modify the tacho from V6 to V8 if you are electronically capable. Not sure about the temperature gauge however.
    I have a V8 tacho and temperature guage if you might want to go down that path.
    I have done the mod myself on a V6. The hardest part was getting hold of the patch harness. In the worst case, you can get a HSV patch harness, and have the one you require modified from that. I probably have the part number for that harness somewhere if you need it - cost a bit less than $100 I believe.
