Dirtbike problems, Can U Fiqure It Out.
Discussion in 'The Pub' started by StealthX, Feb 15, 2007.
Thread Status:
Not open for further replies.
  1. StealthX
    StealthX New Member
    Wyndham, Western Australia
    HSV VX Clubsport.
    Ok bought a bike off a mate today because he needed the cash urgantly for his daughters wedding. ok well this arvo it was all fine toook it down to the track and did a few laps in it.. now im faced with a problem here are the details, see if you can fiqure out whats going wrong.
    Dont want this to sound mean.. but if you dont know what ur talkin about or never been on a bike before :p please dont offer a "wannabe professional" opinion
    Bike: (import) Yamoto 300cc
    ODO: 480km (brand new)
    all afternoon it was runnin fine till 1 lap on the track i think i may of thrown something internally when in gear and under load (riding) it will choke at 4000rpm (cough & splutter) ive tried illiminating things
    1: In nuetral it will rev to whatever RPM like its suppose to
    2: In gear with the clutch in & reved over 4Krpm, its ok too
    3: When riding, each gear 1/2/3/4/5 it will choke at 4Krpm
    4: Chocked on blocks it will run fine in each gear without choking/coughing/spluttering
    ive drained the fuel & flushed the fuel lines.. carby is clean.
    ok.. so lets see what you can come up with.. i dont really want to pull it apart as im going to be reselling it to get my cash back but i cant sell it in this condition. (liek i said my mate needed the cash):bang:
    I have a '05 KTM 600 & previously '03 YZ250. Ive never seen this problem before. Fawkin jap-kr@p Yamoto
  2. 14secvp
    14secvp New Member
    south island newzealand
    vp v6 commodore executive
    "Yamoto"thats probably the problem.Is it two stroker might have blown a crank seal.more details please
  3. Da Flyin Dutchy
    Da Flyin Dutchy New Member
    Cessnock NSW
    Triton VN 3.8lt
    before 4000rpm is everything smooth in gears + power still there or is it lagging aswell
  4. StealthX
    StealthX New Member
    HSV VX Clubsport.
    Dutchy yeah, seems fine up till 4000, soon as i hit somewhere like 3900rpm and change up its ok, then once in 5th and hit somewhere about 4000rpm again it will choke. had it up to 120km/h, so it should boot. now with this problem im only hitting 60 in 5th when changing at 4krpm
  5. Da Flyin Dutchy
    Cessnock NSW
    Triton VN 3.8lt
    *could be either spark plu failing under pressure.
    *parcially blocked feul jets can cause the lag aswell. yet will rev fine when not under load.
    * If you take out spark plug is the tip white or rusty colour or black.
  6. Da Flyin Dutchy
    Cessnock NSW
    Triton VN 3.8lt
    ref to sparkplug
    white tip is lean (fuel blockage)
    rusty tip is excellent burn
    black is flooded
    yellow is bad fuel
    StealthX likes this.
  7. StealthX
    StealthX New Member
    HSV VX Clubsport.
  8. Da Flyin Dutchy
    Cessnock NSW
    Triton VN 3.8lt
    most probs are fuel related. did you refill just before problem started.
  9. Da Flyin Dutchy
    Cessnock NSW
    Triton VN 3.8lt
    dont think you need a rebuild. Will try to keep an eye out tomorrow for more info. If you were in NSW icould look at it.
  10. StealthX
    StealthX New Member
    HSV VX Clubsport.
    yeah, ran fine on the track/trail till it just died as if it ran out of fuel.. checked my fuel tank and it was 3/4 full, restarted it no problems and rode it home slowly, called it a #%#@ing #%@^ and jumped on my other bike n went back to the track. used the same fuel which i use in my other bikes & car filtered unleaded.
  11. Da Flyin Dutchy
    Cessnock NSW
    Triton VN 3.8lt
    if ur other bike has same spark plug type try swapping to test spark plug.
  12. 14secvp
    14secvp New Member
    maybe the little fuel filter in the tank where the tap goes on,or a lump of crud in the float needle jet ,not big enough to get through and jam the float open but enough to slow down the flow. with no load on free revving you wont suck as much gas out the bowl as fast. but when riding might not be keeping up flow wise.
  13. minux
    minux Infidel Bear
    Sounds like bottom end. When it goes, it will be fine neutral as soon as there is load it will just die. I rode for 9 years across Vic as a junior, had the same thing happen many a time.
  14. StealthX
    StealthX New Member
    HSV VX Clubsport.
    Fixed! pulled half the plastics off and cleaned every intake and filter, pulled the spark plug out, looked clean, but of crup on points though, gave it a light scrub wit sandpaper & compressed air. took it for a strap n its kickin even better now. thanks again guys
Thread Status:
