Disable immobilizer?
Dti-dan
Illawarra
VZ 175kw 3.6
My vz has the issues of only starting when it feels like it. Not sure if it's to do
With the key or bcm. Is there a way of disconnecting it until such time as I can get it fixed?
Regards
Dan
PRAVX II S
Australia
Commodore
What do you mean starting when it feels like it?
Does it crank over but not fire,or do you turn the key and nothing happens?
Dti-dan
Illawarra
VZ 175kw 3.6
Car will crank but not fire. Sometimes it take 5 mins to start some times 2hrs
azazeldeath
Donating Member
34
Welshpool Vic
VK Holden Commodore Wagon w/3.8L Buick
Crank but not fire? That means its mechanical, as far as I remember if its the immobilizer it just wont crank, it'd be like turning the key without the battery almost.
When it cranks, does it sound like its trying to start? Or does it just turn with no detonation? And when it runs, does it run rough? Or sound like its got an old 8 in it? (in other words is it missing?)
Finally any error messages at all?
PRAVX II S
Australia
Commodore
check for spark while it is cranking over.
if there is no spark then go into CAS,COILS,EFI RELAY,IGN MODULES.
If there is spark could be the fuel injector no trigger from cpu.
Or go to a workshop and get it fault coded.
PRAVX II S
Australia
Commodore
Hey mate it still can be a immobilizer problem not the key side but the BCM to PCM communication error.
If there is then there will be no injecter trigger from the cpu.
azazeldeath
Donating Member
34
Welshpool Vic
Every commodore I worked on with Immobilizer problems wouldn't crank at all. But it is still possible that it is.
PRAVX II S
Australia
Commodore
Yeh mate thats right because the BCM wont trigger starter relay hence no start like having no battery in the car.
But the PCM AND BCM also talk together. On vx onwards when changing the BCM or PCM you have to make a security link via daignostic machine.
heyitsEnricoPallazzo
Big block Alloytec
VZ A4 Saloon
Dti-dan
Illawarra
VZ 175kw 3.6
Hey guys thanks for the replys
When the car is running it runs fine, smooth with no break down in power. I am sorry for my
Not so complex description of the issue
So....
The key works locks and unlocks, but the car does not seem to de-immobilize so it will do everything but start. Some times you jump in and go... Sometimes not.
There is no frequency in it ither. It will got two weeks with out an issue then do it everytime time you start it in one day
Tho is prone to doing it when both my boys are upset and in the back
