disabling EGR give more power?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by SweetWagon, Dec 17, 2006.
  1. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
    The other day i pointed out the EGR (Exhaust Gas Recirculation) on my dad's VT Ecotec. Anyway he was saying that if we could disable it somehow it might put out some more POWER :D . So if i just disconnect the wiring going to it will it cause any foreseen problems that you know about? has anybody else done this? cheers
  2. VTPREDATOR
    VTPREDATOR New Member
    Warwick
    VE SS SPORTSWAGON
    it does jack **** for performance. dont bother
  3. GOTMYN
    GOTMYN Stab it and Steer...
    Mornington, Vic
    Whippled 5.7, VE SV6, GU Patrol 3.0DI
    Egr....
    The Nipple welded to my pacemakers is connected to the EGR pipe....... However the extractors have not been drilled out for the gas to circulate through the nipple.... Is this a problem?
  4. DumpedVT
    DumpedVT New Member
    Ballarat
    VT 2 Clubsport, Astra J turbo, VN Ls1,
    the sensor will tell the computer there is a fault if it is disconnected or not operating correctly, as for leaving it disconnected, i tried it, didnt make any differnce and car ran like ****.
  5. Cheap6
    Cheap6 New Member
    VP Exec
    The EGR is controlled through the PCM and doesn't operate at anywhere near WOT. In addition to the fault codes and poor running, disabling it would result in no change in power, certainly produce more emissions and likely increase fuel consumption (though probably not greatly).
