Disconnected Hose
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by BrentonK, Sep 28, 2012.
  1. BrentonK
    BrentonK Member
    Australia
    VS Acclaim
    Hi guys, just noticed today that there was a disconnected hose near the drivers side rear wheel which runs to the charcoal canister i think?
    I bought some 3ml fuel hose, but do i have to drop the tank to connect it?
    Also there is a hose on the bottom of the throttle body that sit's on very loose, which i think is making my car idle rough and run like crap, What some good ways of keeping that hose on tight as there is alot of play in it & what's it for, Thanks in advanced.
  2. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    i think if you put your arm up inside the wheel arch and have a feel around the filler neck, you should find one that is disconnected. this will be the one you are looking for. there should be 3 of them. 2 to the dank and one to the metal pipe that runs to the charcoal canister.
    that could be the PCV hose or positive crankcase ventilation hose. it should have a clamp on it. if not just get one to fit and put it on.
  3. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    i'd be shining a torch in the wheel arch up towards the filler before sticking my hand up there (may need to unscrew the cover at the back of the wheel arch to gain access).... i've seen plenty of redbacks making a nice home in that part of the car.
  4. James39
    James39 Gave up on VL's
    Newcastle NSW
    1995 VS Acclaim & 1992 Holden Barina
    There is a cover that can be removed, so there is no need to blindly put your hand in there.
  5. BrentonK
    BrentonK Member
    Australia
    VS Acclaim
    I removed the cover already, and yeah i did shove my hand up there (thank #### i didn't get bitten by any redbacks) couldn't feel anywhere where the hose connected to though, i'll have another try today
