Dissy
the_boozer
no more VK
51
Shitsville Morwell
hilux
yep pull the est fuse lose the est negative from the coil replace with the negative from the distributor connect the distributor pos+ to the big pos+ on the coil you've probably finished before reading this.
the_boozer
no more VK
51
Shitsville Morwell
hilux
i used to drive it and advance it up as much as possible with out it pinging . Flaten it up a nice steep hill, otherwise disconnect and block up the vac advance and set it to 6 degree with the timing light idling in neutral will be all right, if nothing has changed where ever the idle speed is right should be pretty close assuming it was running all right b4. the module usually ends up pretty close to parallel with the oil pump usually where I start .
1985VK
Australia
VK SL
Where did you get the new gear from? Did you get a new coil to go with the new electronic distributor?
