frustrated
- Mar 22, 2006
- 37
- 3
- 0
- VT Station Wagon
G'day,
Having just replaced the steering rack in my VT series 1, I thought I would give some words of advice to anyone contemplating the job.
I bought a reconditioned rack, and followed the instructions in the Gregory's manual.
It is worth spending some time carefully supporting the front of the car off the ground with chassis stands so you have plenty of safe access.
Although you only have to undo 7 nuts to get the rack out, it is a real bastard of a job to get to at least two of them: these are the ones that join the power steering hydraulic lines to the steering gear. These two nuts are different sizes, the bottom one is 16mm (not sure about the top, but it is bigger). Undo the top one first and push it back along the hydraulic line, that improves the access to the bottom nut. It took me about 2 hours and a lot of swearing to remove both nuts! I could only find two positions where I could get an open-ended spanner onto the lower nut, and each position only allowed me to turn the nut about 1/32nd of a turn if that. The steering racks for other model Commodores are a bit different, so you may have more luck.
The only other problem was removing the tie rods from the steering knuckles. I used a fork type "puller", and while it worked, it destroyed the rubber boots and one of the nylon spacers. In any case, I couldn't remove one of the tie rod ends from the tie rod (it was seized on), so I just decided to install two new tie rod ends ($27 each from Auto One). The new tie rod ends didn't have the nylon spacer - it doesn't appear to be necessary.
Reinstalling was straightforward. Do up the bottom nut on the hydraulic lines first, then the top.
All in all, about 6 hours of hard work to save maybe $350. Next time I could probably halve the time, but a lot depends on how easily those nuts come off.
After having the wheels aligned, the car is steering like new and the various "clunks" from the front end have vanished.
