Do i need a engineers cert?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by rhysdalegend, May 22, 2011.
  1. rhysdalegend
    rhysdalegend New Member
    Bacchus Marsh Vic
    Holden commodore VX S Pack
    Hey guys, got a local wrecker who says he can give me a complete vx ss wreck fairly cheap for a straight swap conversion for my vx s.
    after the conversion would i need a engineers certificate for legalities?
  2. Jonno
    Jonno :)
    Vic,
    I doubt it considering the vx came out with the v8 :)
  3. yZoH
    S/E Subs, Melb
    (0.o')
    As long as you have vx brakes, and setup all your emissions like the SS, you simply just roll into vicroads, with receipt, engine number etc, They will check to see if you have upgraded brakes, and the emissions gear.
    An you are good to go.
    Mat
  4. edals
    edals Well-Known Member
    Here
    VE Equipe
    As far as i am aware the front brakes on all VX modals are Twin pots just like the SS modals, And so long as mentioned all the Emission la de da stuff is fitted should be gold. Just let Vic roads of the new engine number :)
  5. 304runner
    304runner ( .Y. )
    Central Coast NSW
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    We did a V8 swap into a v6 calais with the expectation of needing the certs but didnt (as mentioned above) because that model car came out with the same engine fitted. (nsw)
  6. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    The only thing you need to change are the front springs, everything else is the same.
  7. rhysdalegend
    Bacchus Marsh Vic
    Thanks guys, does it matter if its a series 2 vx engine since mine is a series one..
  8. Jonno
    Jonno :)
    Vic,
    Nope dont see why it would
