Do i need to do anything to my auto transmission?
ANL53X
Down South
2000 VT Olympic Edition S2
Hey, i had heard from someone, that they had heard from someone at Holden, that when you do performance upgrades to an auto Commodore you need to upgrade the transmission so it can handle the gain in power, i.e. extractors. I wasn't sure if this is true or not, so i thought i'd ask the people on here. Any advice would be greatly appreciated. Thanks.
GOTMYN
Stab it and Steer...
Mornington, Vic
Whippled 5.7, VE SV6, GU Patrol 3.0DI
Mate, unless your bolting on some serious power, like forced induction, the trans will be OK.
It doesn't hurt to up the line pressures, either with a tune or say a Stg 2 shift Kit.
Trans will be real crisp and avoid premature wear from slippage between gears.
vn_v6
Blumpkin
victoria
87 vl limited edition
is there a way to turn the pressure up DIY?
GOTMYN
Mornington, Vic
Only if you can burn your own Memcal.......
Green Foam or DR Bob or Delcowizz on this forum can help you out, not only with the trans, but also make your engine a bit more responsive.......
ANL53X
Down South
Thanks for that man. Much appreciated.
Anyone else who can shed some wisdom on this subject?
GOTMYN
Mornington, Vic
If it was a 5.0 I could, I have a spare Modified memcal sitting here......
LOWFLYR
50
Greenwith S.A
Enhanced Auto cammed VXSS 5.7A4
my trans lasted 3 months after my cam install then went boom thanks to the increase in power & torque but since having the built 4l65e installed i haven't had an issue
