Do sv6 have canbus wiring for the headlights?
Discussion in 'VE Holden Commodore (2006 - 2013)' started by velj, Apr 26, 2012.
  1. velj
    velj New Member
    victoria
    2010 ve sv6 ute
    As above, just wondering if the headlights need canbus wiring if I get a xenon kit for the foggies? Do any of them need the canbus kit or can I just get any xenon kit?
  2. Zerone_V
    Zerone_V New Member
    Lexus IS350 (SL)
    You can get pretty much any Xenon kit, (Keeping in mind the bulb types), just keep in mind the following,
    1) Stick to a 35Watt kit. Dont go for anything above this wattage.
    2) You should really fit them to projector headlights (I.E. Headlights from a SSV, Calais), as the projector lense will not cause glare compared to the standard reflector headlamps..
    3) ADJUST your headlamps when you are finished so as they DO NOT cause glare for oncoming drivers.
  3. velj
    velj New Member
    victoria
    2010 ve sv6 ute
    Thanks, yeh I was hoping they wernt canbus, I replaced my interior lights with led lights, I thought it might be canbus because when you fade out the flicker
