if you mean issues by having to do the "chain" every about 150,000km that is normal.
if you mean the early alloytec issue in the ve's then as far as I know that was corrected around 2008.
Doesn't fixing the timing chain cost something like 4 grand ? So you need to do that every 150k ?
I mean if you don't fix it the chain blows up and you need to replace the entire engine. I payed 5 grand for a replacement engine in my VZ commodore about 5 years ago.
a timing belt or chain needs to replaced on every vehicle that has one roughly every 100,000 to 150,000 km.
A belt certainly, but a chain every 100K-150K? I wouldn't have thought that to be the case. Most should be last the life of the vehicle (assuming timely and correct engine maintenance). Exceptions exist of course such as the early alloytecs. But these related to an essentially defective product.
So basically an engine which has maintenance costs, say $4,000 to "replace" chain after 100,000 to 150,000 kms ?
Its about half that by Holden and cheaper if you use your own mechanic.So basically an engine which has maintenance costs, say $4,000 to "replace" chain after 100,000 to 150,000 kms ? Don't get me wrong, I absolutely love holden and the VF is awesome but with that kind of maintenance costs I really can't justify it. That would absolutely shatter resale values.
