does any1 have the stock head unit wiring digrame for a ve sv6 2008 model???
ngalea
ipswich
ve sv6
hi does any one have a wiring digrame for the stock head unit in a ve sv6 2008 ??? thanks
westy27
newcastle
VE SV6
Wiring Connector Pin Out Information
Connector X1
Pin 1 : Light Blue : Speaker RR Door (-)
Pin 2 : Dark Green : Speaker RF Door (-)
Pin 3 : Grey : Speaker LF Door (-)
Pin 4 : Yellow/Red : Speaker LR Door (-)
Pin 5 : Dark Blue : Speaker RR Door (+)
Pin 6 : Light Green : Speaker RF (+)
Pin 7 : Brown : Speaker LF (+)
Pin 8 : Brown : Speaker LR (+)
Connector X2
Pin 9 : Light Blue : Front Center Speaker Output (+)
Pin 10 : Orange / Blue : Battery Positive Voltage (RHD)
Pin 10 : Red / White : Battery Positive Voltage (LHD)
Pin 11 : Not Used
Pin 12 : Black : Ground
Pin 13 : Orange : Front Center Speaker Output (+)
Pin 14 : Orange / Blue : Battery Positive Voltage (RHD)
Pin 14 : Red / White : Battery Positive Voltage (LHD)
Pin 15 : Not Used
Pin 16 : Black : Ground
Connector X3
Pin 1 : Not Used
Pin 2 : Dark Blue / White : Common Auxiliary Audio Signal (-)
Pin 3 : Red : Auxiliary Audio Left Signal (+)
Pin 4 : Orange / Black : Navigation Mono Audio Signal (-)
Pin 5 : Pink : Left Audio Signal (+)
Pin 6 : Green / White : Common Audio Signal (-)
Pin 7 : Not Used
Pin 8 : Not Used
Pin 9 : Dark Green : Auxiliary Audio Right Signal (+)
Pin 10 : Pink / Black : Navigation Mono Audio Signal (+)
Pin 11 : Dark Blue : Right Audio Signal (+)
Pin 12 : Not Used
Connector X4
Pin 1 : Light Blue : Telephone Audio Signal (-)
Pin 2 : Not Used
Pin 3 : Not Used
Pin 4 : Orange / Blue : Battery Positive Voltage (RHD)
Pin 4 : Red / White : Battery Positive Voltage (LHD)
Pin 5 : White : Telephone Audio Signal Mute
Pin 6 : Dark Green : Low Speed GMLAN Serial Data
Pin 7 : Orange / Black : Telephone Audio Signal (+)
Pin 8 : Not Used
Pin 9 : Not Used
Pin 10 : Orange : Amplifier Mute Control
Pin 11 : White : Amplifier Enable Signal
Pin 12 : Not Used
Connector X7
Pin 1 : White : Video Connector - Blue
Pin 2 : Not Used
Pin 3 : Red : Video Connector - Red
Pin 4 : Not Used
Pin 5 : Not Used
Pin 6 : Not Used
Pin 7 : Not Used
Pin 8 : Not Used
Pin 9 : Not Used
Pin 10 : Black : Ground
Pin 11 : Dark Green : Video Connector - Green
Pin 12 : Not Used
Pin 13 : Yellow : Video Connector - Sync
Pin 14 : Not Used
Pin 15 : Not Used
Pin 16 : Not Used
Pin 17 : Not Used
Pin 18 : Not Used
Hsv1279
ve HSV
Hey guys... Is this diagram the same for a screen version series 1 or are the wiring in the plugs in different locations.
