Does any1 know bout diff ratios in vt 5.7l 6spd!!!
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by lmacpherson, Mar 10, 2011.
  1. lmacpherson
    lmacpherson Guest
    want to know bout diferant diff ratio and revs. ive run outa people to ask and i cant find anything on the net
  2. GEN3RATD
    GEN3RATD 100% Teflon
    Cannington, WA
    VE Maloo
    What exactly do you want to know etc. What ratio are you looking at.
  3. immortality
    Sth Auck, NZ
    the factory 6spd diff ratio is 3.46:1. and @ 100km/h you should be pulling about 2100rpm in 5th or 1450rpm in 6th. (based on a 235/45/17" tyre profile)
    with 3.7's @ 100km/h, 5th = 2250rpm, 6th = 1550rpm ( i think it's the standard clubsport ratio)
    with 3.9's @ 100km/h, 5th = 2400rpm, 6th = 1600rpm (i think this is the standard GTS ratio)
    with 4.11's @ 100km/h, 5th = 2500rpm, 6th = 1700rpm.
    i think with the factory T56 trans the ideal ratio's are either 3.9's or 4.11's
    all these speeds are approximate allowing for variations in wheel diameters and calibrations of speedo's and tacho's etc
  4. lmacpherson
    lmacpherson Guest
    perfect thankyou thats exactly what i wanted to know
  5. ryan101
    ryan101 New Member
    whittlesea
    vx ss
    ok, just a quick one then, what would be the perfect diff to swap out the standard 3.46 to the gts diff? would that be a good ratio?
