Does anyone have a Holden Parts catalogue?
admir87
vs calais
As the title states, im after a Holden parts catalogue... does anyone have one or know where to get one?
Im referring to the software that shows you diagrams of parts and tells you the part number of them.
Cheers in advance
CAPRILICIOUS WL
WL CAPRICE
You can buy the cd from the parts department.
This cd is a detailed service manual for ur car.
However...
If ur after the diagrams and part numbers u need someone that is good with torrents n stuff , you can download the program which I heard is called microcat Holden or microcat GM.
If u anyone can get there hands on a working version let us know. :)
seq4x4
Sunshine Coast, Queensland
VS
That looks dodgy as all ****..
However, heres the start of a list im creating.
VS:
Accelerator cables:
GM-92055520 Accelerator cable V8
GM-92038207 Accelerator cable V6
Aerial related:
GM-92034850 Aerial bezel
GM-92034730 Manual aerial
Badges and emblems:
GM-92050826 Lion emblem bonnet
GM-92050827 Lion emblem tailgate
GM-92050829 Lion emblem boot
B1126 Caprice badge boot
B1132 Calais badge panel
B1141 Holden badge panel
B1144 Commodore badge panel
B1193 Commodore badge panel series 2
B1198 Commodore badge tailgate
60139B 220i decal
B1261 Clupsport bonnet badge
BD1019 SS body decal
Bolts and nuts:
GM-12554211 Fuel rail screw
GM-92018213 Door belt molding clip
GM-92138025 Fuel pipe mounting clip
GM-92138044 Bush cap
Bonnet related:
GM-92030228 Bonnet release cable
Brake system components:
GM-92027120 Handbrake sedan
GM-92027122 Handbrake wagon/ute
GM-92037536 Handbrake cable statesman/caprice
GM-92037642 Handbrake cable w/IRS
GM-92057585 Handbrake cable clip
GM-92053160 Brake hose front
GM-92053162 Brake hose rear IRS RHS
GM-92053163 Brake hose rear IRS LHS
GM-92053164 Brake hose rear none IRS
Bumpers:
GM-92028560 Rear centre wagon
GM-92040819 Bumperette RHR ute
GM-92040820 Bumperette LHR ute
GM-92042644 Front bumper caprice
GM-92042645 Front bumper standard
GM-92042647 Front bumper statesman
GM-92048855 Front bumper SS
GM-92042656 Bumper end RHR wagon
GM-92042657 Bumper end LHR wagon
GM-92042699 Rear bumper standard
GM-92042717 Support bumper rear
GM-92042737 Rear bumper retainer clip
GM-92044332 Rear bumper statesman/caprice
GM-92045523 Rear bumper bracket
GM-92049120 Calias black & chrome grille RHS
GM-92049121 Calias black & chrome grille LHS
GM-92042659 Silver and chrome grille RHS
GM-92042660 Silver and chrome grille LHS
GM-92042749 Caprice grille
GM-92045680 Black and red grille RHS
GM-92045681 Black and red grille LHS
GM-92049122 Black and silver grille RHS
GM-92049123 Black and silver grille LHS
GM-92051268 Statesman grille to 6/96
GM-92054255 Statesman grille from 6/96
Clutch related:
GM-92052719 Clutch cable V6
GM-92031796 Clutch cable V8
Cooling system:
GM-24500321 Oring bypass hose fitting
GM-92061300 Bypass manifold fitting
Interior lighting:
GM-LII1005 Dome light lense
Door components:
GM-92039810 Window regulator RHF
GM-92133008 Window winder handle grey
GM-92133009 Window winder handle blue
GM-92034533 Inner d/belt charcoal RHR
GM-92034534 Inner d/belt charcoal LHR
GM-92133078 Inner d/belt charcoal RHF
GM-92133079 Inner d/belt charcoal LHF
GM-92049420 Electric mirror LHS
GM-92052946 Manual door mirror RHS
GM-92052947 Manual door mirror LHS
Door seals and weather strips:
GM-RBC1067 Bailey channel kit LHF
GM-RBC1068 Bailey channel kit RHF
GM-RBC1069 Bailey channel kit LHR
GM-RBC1070 Bailey channel kit RHR
GM-H1101 Black inner door belt set
GM-92052986 Door seal RHR statesman
GM-92052987 Door seal LHR statesman
GM-92056196 Bonnet lancing
Engine mounts:
GM-92046314 Engine mount bracket RHS V8
GM-92046315 Engine mount bracket LHS V8
GM-9930472 Engine mount V8
GM-92035589 Engine mount bracket RHS V6
Engine spare parts:
GM-92061867 Dipstick tube V6
GM-92061868 Dipstick V6
GM-24502252 Timing cover gasket V6
GM-24504098 Front crank seal V6
GM-11023589 Sump plug washer pre VH756060
GM-90409376 Sump plug pre VH756060
GM-21007200 Oil filler cap
GM-24507388 Rear main holder plate gasket V6
GM-24507676 Exhaust manifold gasket V6
GM-24502433 Thermostat gasket V6
GM-6PK2725 Drive belt V6
GM-92048388 A/C idler pulley support V6
GM-92056290 Idler pulley V6
GM-92057880 Lower idler pulley V6
GM-92063903 A/C Idler pulley V6
GM-92082702 Idler/tensioner assembly V6
GM-92138512 Idler pulley bolt V6
GM-24507558 Harmonic balancer V6
Z154 Ryco oil filter V6
GM-90467976 Oil filler cap V8
GM-92062750 Dipstick V8
GM-92014559 Water pump pulley
GM-92026658 Idler pulley
Z160 Ryco oil filter V8
GM-140017 Coil pack V6
GM-92060240 Ignition module V8
Fuel system:
GM-0280160552 Fuel pressure regulator V6
GM-0280160593 Fuel pressure regulator S/C V6
Z200 Ryco fuel filter
Windows:
GM-92043557 Rear windscreen tinted
GM-92049348 Front windscreen tinted
Heat parts:
GM-92049436 Heater hose tube assembly
GM-HT1003 Heater tap 2 way vacuum
Ignition barrel, housing and keys:
GM-90191415 Ignition housing kit
GM-90306520 Ignition switch housing and bearing
GM-92048530 Ignition barrel and key
GM-92049906 Ignition switch
Indicator stalks:
GM-92043130 Indicator stalk no cruise control
GM-92043131 Indicator stalk with cruise control
Lamps and components:
GM-92042672 Fog light assembly RHS
GM-92042673 Fog light assembly LHS
GM-92043932 Fog light bezel RHS
GM-92043933 Fog light bezel LHS
GM-92140307 Bulb socket side flasher
GM-92141382 Clear side flasher
Mouldings:
GM-92041549 Rear windscreen moulding ute
GM-92045104 Rear s/seal moulding sedan RHS
GM-92045105 Rear s/seal moulding sedan LHS
GM-92047831 Rear s/seal moulding sedan lower
GM-92049404 Rear s/seal moulding sedan upper
Panels:
GM-92033502 Door skin LHF
GM-92033503 Door skin RHF
GM-92035422 Door shell statesman/caprice RHR
GM-92035423 Door shell statesman/caprice LHR
GM-92036799 Tailgate ute
GM-92036800 Tailgate skin ute
GM-92038206 Door shell wagon RHR
GM-92038207 Door shell wagon LHR
GM-92038209 Door shell sedan LHR
GM-92041070 Tailgate skin wagon
GM-92041877 Inner guard panel RHS
GM-92041878 Inner guard panel LHS
GM-92042244 Front guard RHS
GM-92042245 Front guard LHS
GM-92042248 Radiator support panel pre 5/96
GM-92042250 Front guard statesman/caprice RHS
GM-92042251 Front guard statesman/caprice LHS
GM-92042252 Inner guard liner RHS
GM-92042253 Inner guard liner LHS
GM-92042420 Boot lid statesman/caprice
GM-92043699 Boot lid
GM-92043840 Bonnet caprice
GM-92044857 Door shell RHF
GM-92044858 Door shell LHF
GM-92050518 Bonnet
GM-92050521 Bonnet statesman
GM-92050524 Bonnet late caprice
GM-92052950 Tailgate wagon
GM-92054477 Radiator support panel from 5/96
GM-24505969 Oil pressure sender
GM-12160244 IAT sensor V6
GM-92053314 L67 OTR CAI
GM-92053315 L67 OTR CAI duct
GM-11072461 Front guard retainer clip
GM-92043285 Dash fascia
GM-01997210 Canister purge solenoid
admir87
vs calais
Hi, thanks for that.
I'm still in need of the whole catalogue for models up to ve.
Someone must have the cd with a holden parts catalogue??
VS_Pete
Donating Member
They use the internet now.
And it is called microcat
