Does anyone know how to remove error codes on vz??
Exidor
I come in peace.
Earth. For now....
Used Martian spacecraft
Holden Tech2 or OBD2 scantool.
andyman
The Only 6sp VZ Wagon
34
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
which fault is it
srs
svs
powertrain
reduced performance
abs
overheat
etc etc
need more details, and has the problem been cured?
PaulSV6
CHE Tuned 156.8rwkw
Castle Hill
VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
SKNOT9
All hope is gone
Lobethal, South Australia
VS series II Acclaim
basically i installed a new headunit and i blew a fuse, and i accidentally removed the auto trans fuse when replacing the other one and then later when i turned it on it went into limp mode. then it logged an error code but i have now replaced the fuse and its all good.
Exidor
I come in peace.
Earth. For now....
Buy yourself a scantool.
It will come in handy if you do your own work.
andyman
34
Orange, NSW
have you tried disconnecting the battery? could possibly remove that, otherwise scan too for you!
Torquative
Sports Economy
VE SV6 3.6L SIDI 6sp
surprised the auto box fuse set it off, Ive had mine out many times before without an issue
