[Buick] Does anyone now how to modify a VR V6 for a tow vehicle
Discussion in 'V6 Development And Modification' started by pjdm1980, Aug 10, 2009.
  1. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    I want a bit more torque for towing on the highway but still good fuel economy?
    Where should i start?
    Exhaust (done)
    Cold air intake (done)
    But i didn't notice any difference except more noise!
    Any ideas?
    Thanks Pat:bow:
  2. Troy5L
    Troy5L building a lemon
    Mornington peninsula
    Gu patrol td42
    maybe get in contact with greenfoam, and get him to do a reprogrammed memcal for ya
  3. beeb
    beeb New Member
    VR exec & HZ Wagon w/ VP V6
    Big trans cooler. Won't help torque, but it might save you auto...
    Slighty quicker diff-gears would be one way around the issue, these V6's struggle sitting at 100 on the freeway, a few more revs might make the motor a bit happier (closer to peak torque...).
    I towed a VP V6 & auto 50km yesterday in a box trailer behind my VR, and it wasn't liking it. Just didn't like having that much load at such low revs i feel.
  4. Maci
    Maci New Member
    Goulburn NSW
    2003 Holden Statesman
    i agree with beeb, a transmission cooler is definately in order if you're going to be towing a fair bit, my vx v6 auto had a transmission cooler and a hayman reese towbar fitted before i owned it, and did a fair bit of towing, and the transmission is still very strong.
  5. immortality
    Sth Auck, NZ
    diff gears, trans cooler and a tune
  6. 383 hatch
    383 hatch Well-Known Member
    Cowes, Phillip Island
    V8...You can't beat a V8 for towing, especially a 5 litre!
  7. pjdm1980
    Geelong, Victoria
    Yer but i use the car for every day family bang about as well as driving 150km's to work every day!
  8. pjdm1980
    Geelong, Victoria
    What about changing the cam?
    And what specs should i try for?
  9. beeb
    beeb New Member
    A cam swap would be large expense for very minimal changes. You could try something like a VN S1 cam, as they had the most "instant" torque of the V6's, but it really would not be worth it. You might get about a 2% gain, for probably $500+ bucks and a weekend's work.
    What are you actually trying to tow, and how often? If it's just the occasional tow, just get the trans cooler in there and go easy on it when you're towing... Short of adding a positive-displacement supercharger, or adding some cubes, There's no "cheap" fix for more torque.
  10. pjdm1980
    Geelong, Victoria
    Tow every second weekend usually bikes but sometime a caravan but nearly always long distance and it struggles.
  11. GOTMYN
    GOTMYN Stab it and Steer...
    Mornington, Vic
    Whippled 5.7, VE SV6, GU Patrol 3.0DI
    Bolt on some Y/T 195:1 rollers, they will compliment the exhaust and cold air....
    Then get it tuned, you will be surprised :)
  12. acarmody
    acarmody Donati..Whoa Green
    VX Berlina
    I know its a typo but can I get some 195:1 rockers for my car. 62.156" of valve life, may need modified rocker cover. :p
  13. beeb
    beeb New Member
    How exactly do you measure life in inches? :p
  14. spirto
    spirto Member
    VQ Caprice II
    Diff Upgrade - 3.75:1 at least.
    Trans cooler (must have).
    Get transmission flushed and have an additive added to help it along.
    Check Tailshaft bearing and universal joints, replace as necessary.
    Check Stub axels if indepdant rear, with heavy duty LPG Springs
    If Solid axels, you can upgrade springs here, and add some pump up shockers, but don't wire them up from one air nipple seperate is the go.
    Exhaust you should keep a bit of backpressure on it, too big only makes noise not torgue.
    And considering your going for towing not brawling, 2.5 Inch single with good flowing muffler should have been the choice.
    Best of luck, with the money your spending here, to make it function, you might have been better with a old school UTE..... perhaps?
    Cheers.
  15. 383 hatch
