dwae01
- Apr 16, 2010
- 23
- 2
- 3
- VN Calais (sold), HSV Grange (sold), VZ Cross 6
I have an intermittent error that has occurred half a dozen times a couple of weeks apart. I turn the key and nothing happens. Sometimes I do it half a dozen times before it starts. After it starts I check a "Check Engine" message that stays until I clear it but the car runs fine. On a couple of occasions the error message disappeared without me doing anything. Sometimes there is a distinct delay between when you turn the key and the engine starting to turn over. Yesterday I could not start the car at all. I must have tried more than 20 times. Would not turn over at all. Eventually I went and got the other key and the car started first go (could have been a coincidence). After it started I turned it off and tried the first key again and it started first go. Sometimes the problem occurs when the engine is cold and sometimes hot. Usually when I put on the T2 to clear the DICs there are three error codes:
P0601 Symp 00 Replace Electronic Control Unit (ECU)
P1632 Symp 48 Immobiliser Fuel Disable Signal Received
P1668 Symp 00 Alternator L Terminal Circuit Malfunction
Working on P1632 I have done a bit of work on the ignition barrel bezel to make sure it contacts the nib of the key but that doesn't seem to have solved the problem.
Any suggestions?
Any suggestions?
