I don't get this, maybe I'm missing something?
If the Bi-modal doesn't open till 3K, if you pull out the relay/fuse it will never open cause it needs power to open?
which relay? is it labelled?
nothing else in the car dependent on that relay?
any difference in performance or fuel usage due to pressure or other black magic **** I dont understand?
Manual sedan, hsv headers and cats, hsv floor section, factory bimodal rears with the relay pulled. Slight drone. Whisper quiet at cruising speeds though thankfully.
I'm wondering if the Bailey tip is doing anything to create the drone, given its designed to pump exhaust noise back into the cabin.
I've got a mate with a VF clubby, manual, same exhaust, relay pulled, zero drone at any stage.
On the outside both cars sound much the same, so I can't see there being much difference between the Holden and hsv bimodal mufflers.
bigjim, Im still chasing the middle section off a 340 Clubsport, does it all connect up well to the Holden rear mufflers? is it worth fitting the HSV centre section of the exhaust? will the HSV headers/cats hook up to the Holden centre section if I dont use the HSV centre section? I heard someone say to fit the HSV centre section because of the O2 sensors otherwise you have to drill a hole into the Holden centre section to accommodate.
Can you shed some light on this for me please.
The HSV system will bolt up without issue in any combination. Headers and cats will bolt upto the factory catback.
As for the hsv floor section it will bolt upto the factory rear mufflers without issue. You just need to make sure the hsv system has the ball/knuckle joint rather than a flat flange.
In regards to the O2 sensors the factory manifold and cat assemble contains both upstream and downstream O2s. The hsv headers only accommodate the upstream O2.
Depending on what year/engine the HSV floor section came off it will have O2 bungs in it. Otherwise you need to have them welded in, cheap and easy done though.
If you run hsv headers and cats with the factory catback you will need to have bungs fitted for the downstream O2s
