Doe's this sound like warped rear brakes?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jas98, Dec 10, 2011.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    hi, when breaking in my vs sometimes while coming to a stop (moderate braking) the car sort of jolts forward and back and i can feel the brake pedle going up and down, no shaking in steering wheel etc just this, kinda like braking then pedal pushes up then braking (but a lot quicker), is actually dangerous sometimes. could it be the diff??
    any help?
    thanks
  2. fully_carver
    fully_carver New Member
    vr
    it sounds exactly like warped brakes way to test remove wheal and put a steel ruller on the disk best done hot. i saw in the repco caterlog disks and pads for 100 bucks a pair
  3. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    fully_carver is on the money - warped or distorted brakes....could be front or rear. Disks are cheap and an easy change..
  4. James39
    James39 Gave up on VL's
    Newcastle NSW
    1995 VS Acclaim & 1992 Holden Barina
    Well sometimes they are.. on a donar VS I had here I could not get the front ones off,,,
  5. Kernal
    Kernal New Member
    NSW
    Thats when you reach for the hammer!!!
    Note: if your not going to use the rotor again use a normal hammer (otherwise a rubber mallet). You kind of have to shock it to break its hold/seal. Sort of like using a spanner and hammer to shock a seized nut. (It think thats the term, 'shock', so dont crucify me if its not, im an accountant not a mechanic lol)
  6. TI3VOM
    TI3VOM Active Member
    Here there and everywhere.
    VT Commodore
    Yep sounds like the REAR brake rotors are possibly warped, if they were the front you would have your steering wheel shake, if there the back you will feel it in the pedal.
  7. jas98
    jas98 Active Member
    maryborough QLD
    thanks guys will sus it out, i got a set of disks here mite try and change em one by one and see, as i got slotted disks all round (RDA front and DBA rear although they were bothe DBA front and rear i got em seconhand and the fronts warped straight away so it could be the backs, anyway got brake fad last night for the first time (scard me lol) buut i was useing them pretty hard etc)
    will get around to it and let yous no how it goes
  8. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    Before you try and get the rotors off, spray around the bottom of the wheel studs where they come out of the rotor with a penetrating agent, such as Penetrene, WD40, RP7 etc. Let soak in for 5-10 mins before you try and remove the rotors.
    IMPORTANT - make sure you let the handbrake off before you try and remove the rear rotors.
